Old 08-02-2005, 02:32 PM
mdemos
Default Enclosure Painting
Hi. I have a computer enclosure that has a top and a bottom. Currently when this is powder coated, each part is coated separately. Because I need to have metal-to-metal contact between the two parts when they are assembled, masking is necessary where the two parts are met.
Is there a way that the parts could actually be powder coated while they are assembled? This would eliminate the need for masking?
Thanks,
Mike.
Old 08-02-2005, 05:34 PM
LeeParsons
Send a message via ICQ to LeeParsons
Do you have sufficient access to get the gun into the enslosure it whould work.
Old 08-02-2005, 05:56 PM
mdemos
Default Paint sticking?
Lee: Wouldn't I have problems with the two parts sticking together? I am using an epoxy powder coat.
My issue is that I have had one supplier that gave me a sample and said he had no problem doing this. My other supplier had problems with the parts sticking together.
Thanks,
Mike.
Old 08-02-2005, 07:00 PM
customandsound
Guest
Posts: n/a
Epoxy ... Just take them part and shoot and cure .. i Powder coat then when i am cured i take a belt sander to the end to remove the powder... even when i polish the letters i sand it off with the belt sander...
You can shoot them in a whole and it will work when taking apart score the joints with a blade to give you a clean break
Old 08-03-2005, 10:40 AM
LeeParsons
What Chuck said, use a razor knife to score along the break line of the two parts.
Old 08-04-2005, 02:25 PM
customandsound
Guest
Posts: n/a
thank you lee
Old 10-06-2005, 06:38 PM
PowderVisions is on a distinguished road
Default Re: Enclosure Painting
You need the areas free of powder for ground. I have painted thousands of these boxes and I never had any luck painting them together. The problem is that it is very difficult to get powder onto the edging without parts sticking and/or looking terrible. We always take boxes and cut them as a mask on each part and pull them out prior to cure. We still use steel mask as well.
Painting over chromed plastic &chromed exhaust pipes gkohler Other Metal Finishing Questions 4 07-28-2005 03:07 PM
PAINTING A METAL PLATE moondog7201 Other Metal Finishing Questions 0 11-23-2004 01:01 AM
Painting over a Powder Coat Finish bethjohnson Powder Coating Questions 2 09-17-2004 03:49 AM
how to prep metal for painting coorsman Other Metal Finishing Questions 2 08-16-2003 06:26 PM
Painting over a powder coat chromo Powder Coating Questions 1 01-29-2003 02:20 AM
