My sandblaster came with the sand already in the unit. It Looked to be the type of media that looks like sand without the silica. It was really dirty and had broken glass in it so I replace it with Black Magic media. The problem it would not suck up through the pick up tube. The Sand did not have a problem. Should I invest in one of those pressurized hoppers that keeps the media at 40psi?? Or just go back to the sand/ without silica?
What do you all use? By the way my compressor is 80 gallons so lack of air is no a problem Your thoughts, Mick |
Good idea, however, it did work prior to switching to the other media. How do I know if the nozzle has the correct size to support this grit of media? I bought the unit used and like I said it did work with the sand (again no silica). Just won’t suck the Black beauty. Frustrating
A couple of things. A: What size Black Beauty are you trying to use? It comes in Fine, Med & Course. You should be using fine. The course may not feed thru your nozzle size B: Make sure there is no breaks/holes in the rubber/plastic portion of the pick up hose that runs to the media (hard pipe) pick up tube. C: Is the media dry? It's been very humid here lately D: Is the nozzle clean & open? E: Is the media falling back done into the hopper so it can get ppicked up? F: If your media pick up tube is one hose with a hard pipe pick up feeding into the media, does the pick up tube have a hole in it's side about 1/2 up the tube & located outside of the media? If not ,you may need to drill one, because different medias need different lift pressures If you already have a hole, you may need to make it smaller (tape over 1/2 the hole with electrical tape. All in all the syphon sytem is pretty simple. But you must make sure all of the above is in order. Good Luck Bob
www.capecodpowdercoating.com |
My media is course. The pickup tube is in the bottom of the hopper and is clear plastic, so I can see inside. No hard line the end is cut at a 45. What is strange is the media goes up the tube and just stops at the gun. So, I swaped guns, lines and nothing. Are there different sizes orfices on the gun to use with the various media? Maybe I have the wrong size?
I really appreciate the help, I PC'ed my first parts and they came out fantastic!!! This is what I did; 1. Sandblasted part prior to switching to Black Beauty. 2. Degreased the part and air dryed 3. Placed in oven at 400 for 15 minutes 4. Took out and let cool to 125 5. Sprayed part ( Gun worked EXCELLENT ) Remove the tip!!! 6. Placed back in oven at 400 for 15 minutes 7. Took out and let cool. Will try the oxide on Monday. Once again I could not have done this without this forum and all your help!!! [/img] |
| info on blast media | Blademan | Powder Coating Questions | 7 | 05-18-2007 06:58 PM |
| Media blasting?? | trsick | Powder Coating Questions | 4 | 02-02-2005 10:03 AM |
| Anyone with experience on tumblers or the media to use? | krsimulis | Metal Polishing Questions | 0 | 06-02-2004 01:18 AM |
| What type of media to use? | Tito | Other Metal Finishing Questions | 1 | 05-27-2004 08:10 PM |
| question on sandblasting off chrome | hearse71 | Metal Polishing Questions | 1 | 04-11-2003 09:08 AM |
