Old 08-08-2005, 10:57 AM
cruizer's Avatar
cruizer
Default Removing paint from the corners....
I have been given a stackable monitor stand from a lady at work to do in Bubble Gum color. These are very simple piece of metal formes into the following shape: [______] (this representation is upside down). There is also a folded edge on the front and back (the side being the [ and ] ) that creates a corner. I an having a hell of a time getting the paint removed out of the corners and inside seams. And the very lower botton lip. I've used paint stripper, glass bead, and a wire wheel. The paint stripper seems to have done all it can do. My bead blasting setup is very weak. And the wire wheel won't fit in there. I'm at a loss here.
Old 08-08-2005, 11:47 AM
Zpider
I think the only way to remove it is to use some more agressive media for the blaster, glass dont remove that much, its more for givning a smooth surface than removing...
WEIRD Performance & Coatings
Sweden
Old 08-08-2005, 12:04 PM
cruizer's Avatar
cruizer
OOhhh. Switching media is such a pain.
Old 08-08-2005, 12:06 PM
Zpider
That why i have 2 cabinets
Sweden
Old 08-08-2005, 12:11 PM
customandsound
Guest
Posts: n/a
Coal slag will remove that with no problem glass bead is good for smoothing and soft metals
Old 08-08-2005, 12:36 PM
try burning the paint off with a torch
Old 08-08-2005, 01:41 PM
cruizer's Avatar
cruizer
Now there we go!! I'll give that a try before I go and change my media.
Thanks guys, for all the help thus far.
  #8 (permalink)
Old 08-10-2005, 06:30 PM
Homeseller
fxtcguy98 must really be Jessy James during his day job.
Has anyone ever seen them in the same room together?
  #9 (permalink)
Old 08-11-2005, 11:33 PM
customandsound
Guest
Posts: n/a
when using heat be careful not to warp the metal some jap metal is soft and will distort easy
  #10 (permalink)
Old 08-13-2005, 12:07 PM
mtnbiker is an unknown quantity at this point
I use glass bead for everything. Seems to take everything off real nice, except powder coating. Takes a little time with annodizing too. But, all paints... not an issue.
Paint repelling? cruizer Powder Coating Questions 3 08-19-2005 11:14 AM
transparent paint after polishing Pol3000 Metal Polishing Questions 4 04-23-2005 07:18 PM
Wanting to paint turbo exhaust manifold and downpipe NCspecV81 Powder Coating Questions 1 12-26-2004 07:45 PM
BEWARE!!! Problem Plating Car with Metallic color paint! GoldiesPlating Electroplating Questions 0 08-29-2003 10:29 PM
Equipment paint or powdercoat? chromo Powder Coating Questions 1 06-09-2003 12:16 AM
