+ Reply to Thread
Results 1 to 5 of 5
Thread: PC prepping??
  1. #1
    Default PC prepping??
    What kind of preperation needs to go into the part being powder coated. Obvisouly it has to be clean and degreased. Im talkin as in sand blasting, bead blasting, etc.
    Im setting up a lil in house chroming shop, and want to add a PC oven also. I just dont want to spend the $ on a bead blaster, etc.?
    What r my options
    Share with Facebook
  2. #2
    Join Date
    Jun 2004
    Posts
    369
    It depends on what you're calling parts but small blaster is almost a gotta have to strip and prep "parts"
    IMHO
    Share with Facebook
  3. #3
    Join Date
    Feb 2005
    Location
    belleville michigan
    Posts
    635
    well your options are buy a blaster or hire that part out. to pc the "part" it has to have a blasted profile of the pc probably wont stick. there are exceptions but even chrome plated parts have to be sanded or bead blasted to give some grip for the pc.
    Share with Facebook
  4. #4
    Join Date
    Mar 2005
    Posts
    64
    Not necessarily Pickleboy! Okay, ordinarily you clean, strip, sandblast and powdercoat material, but you can coat a part, like say Chrome and get away with it. It won't be as durable, but it can be done.
    I've been thinking about it since my buddy asked me about it when I did his hyabusa motorcycle parts.
    I've done it in my beginning with powdercoating with a chrome breather cover. I just cleaned it and powdercoated right over the chrome. It took too! Later, I found that I could scrape it off like paint.
    Share with Facebook
  5. #5
    customandsound Guest
    you can build a blast box for reasonable this will hold you over .. i build one out of plywood and a cheap blast for 30 bucks
    the chrome has to be stripped in order for you to get good results .. just like heavykote said .. it will flake off after a while.. i use to just blast clean and coat then it came back and bit me in the rear end .. but you learn from your mistakes
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Prepping stainless part for polishing
    By danbajwa in forum Metal Polishing Questions
    Last Post: 08-10-2005, 08:32 AM
  2. Prepping aluminum
    By rdkeng in forum Powder Coating Questions
    Last Post: 01-10-2005, 08:52 AM
  3. Prepping Aluminum
    By Benny10 in forum Powder Coating Questions
    Last Post: 11-11-2004, 12:24 AM
  4. Prepping cast iron.
    By Stytooner in forum Powder Coating Questions
    Last Post: 08-04-2004, 09:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
