Old 08-13-2005, 12:16 PM
mtnbiker is an unknown quantity at this point
Default getting powder into tight places
What are some tips and tricks to get powder into tight places. I ahve come across a couple cases. I could load up on powder, but that doesnt look the best.
-holes/tubes say an inch or two deep and I want powder inside
-tight corners... any that forms a sort of V shape
I am assuming that the two negative charged parts repel the powder?
I tried turning off the power to get it there... but no luck.
Any help?
Thanks
Old 08-13-2005, 01:06 PM
customandsound
Guest
Posts: n/a
fog it ..
Old 08-13-2005, 01:11 PM
sdold's Avatar
sdold is on a distinguished road
Try heating up the part to about 200 degrees, and begin shooting that area lightly with no gun power. I did this one time and it seemed to work pretty well.
Old 08-13-2005, 02:58 PM
wamontgomery
I have one of the hobby guns and to get into tight corners I pull the deflector peice off and it shoots a nice straight path where I want it. Works great.
Old 08-13-2005, 03:31 PM
customandsound
Guest
Posts: n/a
cut the air back to 10 pis or less to fog the powder on the part. By heating the part the powder will stick if you want to
try that ... By preheating the part the powder will stick in the corners
beater . When you powder coat the corners the air tends to back out and when that happens the air blow's the powder right back off.
Old 08-14-2005, 02:31 PM
customandsound
Guest
Posts: n/a
thank you...
Tips and Tricks non-stick Powder Coating Questions 27 11-11-2007 03:01 PM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 09:15 AM
Finding a place to powder coat RCLSolutions Powder Coating Questions 3 05-04-2005 10:42 PM
Gun spitting excess powder pdeinc Powder Coating Questions 8 10-21-2004 04:21 PM
type of powder? PaulW Powder Coating Questions 2 07-09-2003 12:13 PM
