FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 08-17-2005, 04:04 PM
OKTRX450R
Default Pretreatment
OK, so I am going to powder some pieces on my atv...
1: I bead blast the pieces,
2: wipe them down with paint thinner or final clean,
3: preheat to 200*,
4: shoot powder,
5:bake at 375-400* until yummy.
Is this correct?
Should I use the Iron Phosphate? Pros/cons...
Thanks for the help!
Old 08-17-2005, 04:50 PM
wamontgomery
Default Re: Pretreatment
Sounds correct to me...But when pre-heating (outgassing) I usually keep it around 250-300 and I outgass it for 10-15 minutes.
Old 08-17-2005, 05:24 PM
Normally you don't need to pre-heat parts unless you need to off gas them.
Old cast iron or cast aluminum..
I was always told to off gas at a higher temperature (50-75+) than you're going to cure the powder at.
Old 08-18-2005, 01:59 AM
speeddemonrodsteration's Avatar
thats what I've found work best- out-gassing at a higher temp, I do about 450 to 475 degrees- I've heard either hotter or longer than your curring temp/time for out gassing
Save the trees- burn Rubber!
Old 08-18-2005, 12:26 PM
jagboy69
I have mostly done just steel parts for an old car, and I have to confess. I have never done anything to my parts except bead blasted, used compressed air and a clean brush to dust the parts off and then PC'd them. Does this make me some sort of hack? My parts have been coming out great. I suppose I am just lazy. lol
Old 10-06-2005, 05:26 PM
PowderVisions is on a distinguished road
Be very careful about the paint thinner for cleaning because most solvents are oil based. I would use isopropyl.
Old 10-07-2005, 06:27 AM
Blademan's Avatar
Blademan is on a distinguished road
I usually blast, dip for a few sec's in muratic acid (diluted) wash off with water, dry, and wipe down befor shooting with acetone..
Pro-Tech Powder Coating
93976 Ocean Way
541-247-8168
protech@harborside.com
Gold Beach,Oregon
pretreatment scoober Powder Coating Questions 1 03-01-2004 05:23 PM
pretreatment tank bzer1 Powder Coating Questions 6 01-22-2004 10:07 PM
Pretreatment of Aluminized Steel???? Brog Powder Coating Questions 2 01-13-2004 11:02 AM
