Perhaps your just smarter than everyone else here. How about you provide links to this information that you say is readily available... |
Thanks guys and gals for all the info on blasting aluminum. I just started in the PC process and this fourm is GREAT! Now on to the point of Blasting aluminum products. I build very high horsepower small block chevys ie.2.5 hp per cid at 10,000rpm and I use crushed walnut shells on the pistons then bake them in the oven to burn off any residue left then rinse with min spirits. The shells are less intrusive to the aluminum especially in the ring lan area and remove the carbon fast and easy. The other medias will get imbeded in the pistons and cause friction and particals in the oil thus reducing the life of the engine. So I believe the same process for PC will work. Thanks for letting me put my two cents worth in and hope it helps someone else. fastopel
I had some similar results when I put 125 psi black beauty to some aluminum pieces pits pops. This clears up the mystery.
-Powder Plus |
A guy brought down an older corvette frame swearing by baking soda as it won't warp the fiberglass body. After he saw the different in AO and BS, he took his baking soda back home haha |
