Old 09-12-2005, 09:47 PM
KZjim's Avatar
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
Cool Blistering??
I am currently coating the hardware from a guys drum kit..... his haedware is chrome and its now satin black....
I preheated the parts and coated... no prob.. but the chrome on the a few of the parts blistered.... has anyone had this problem with chrome stuff... ?
I have done valve covers and air cleaners with no problems.
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
Old 09-13-2005, 02:27 AM
nuttyman's Avatar
nuttyman
Default Re: Blistering??
no, but the hardware you speak of is probably 20 guage or thinner correct? if so then it is probably warping under the heat &/or the integrity of the chrome's adhesion has been compromised.
nutty
Old 09-13-2005, 08:32 PM
KZjim's Avatar
the parts are all cast, except for the rings that hold the drum head down... cheap chrome job?
Old 09-14-2005, 09:30 AM
nuttyman's Avatar
nuttyman
perhaps, or it has been beat long enough that it is starting to peel?
Old 09-14-2005, 12:26 PM
The drum hardware is most likely potmetal and therefore it will outgas when heated and bubble even the worlds greatest chrome job.
Old 09-14-2005, 08:15 PM
tavo1765 is an unknown quantity at this point
Yep, its outgassing. You need to get outgass forgiving powder to help you and pre heat the **** out of it to a temp of at least 450f for 40mins to help reduce the problem.
Old 09-15-2005, 12:27 PM
No, you will have to remove the chrome first, it's most likely blistered under the chrome, then use the special powders
  #8 (permalink)
Old 09-15-2005, 11:58 PM
gtabadboy
What special powders are these?
  #9 (permalink)
Old 09-16-2005, 12:24 AM
CaptainChauncy is an unknown quantity at this point
Most likely outgass forgiving powders..
  #10 (permalink)
Old 09-16-2005, 09:48 PM
KZjim's Avatar
What about a lower temperature and a longer cure time?
