FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 10-03-2005, 03:25 PM
DaveNJ is on a distinguished road
Default painting decals on powder coat
What kind of paint is used to air brush decals and graphics on a powder coated bicycle frame, then clear powder coated over?
Do I need a special type of paint that will withstand the cure temperature of the clear powder coat or will most lacquers or enamels work OK?
thanks,
Dave
Old 10-03-2005, 04:53 PM
Default Re: painting decals on powder coat
Lacquer would probably work, do a test piece first though.
Old 10-03-2005, 10:30 PM
pickleboy's Avatar
most liquid will not hold up to powder temps and if the do you still have the problem of them causing the clear powder to lift off. if you plan on liquid graphics i would use liquid to clear and save the heartach of haveing to start over. but as popeye said you can try on a test plate a see for sure.
Old 10-06-2005, 04:04 PM
PowderVisions is on a distinguished road
Most decal makers use a special high temperature decal for use under powdercoat. Regular vinyl decals will not take much temperature change. I would contact the decal manufacturers for their suggestions.
Old 10-06-2005, 07:45 PM
I was not referring to vinyl decals in my post. I meant airbrushing letters with paint such as on a bicycle frame.
You can see this process on Spectrum Powdercoating website where the employee does this whole process on video on a bike frame. Of course they don't tell what kind of paint he is airbrushing on the powdercoated frame. Then he clear powder coats the whole bike.
Old 10-06-2005, 09:22 PM
They are probably using either an epoxy or polyurethane catalized paint.
Old 10-07-2005, 08:21 AM
DaveNJ,
Stick with the lacquer first... it usually is sprayed very thin and the solvents evaporate quickly. Epoxies, Urethanes and enamels that a LONG time for the solvents to evaporate.
I used to do a lot of air brush work and lacquer is the preferred medium..
Test first
  #8 (permalink)
Old 10-07-2005, 11:15 PM
crafts ceramic paint
it's used for painting ceramic crafts like pottery and it has to be baked at 350-400 same as powder coating
  #9 (permalink)
Old 06-08-2007, 10:13 AM
LittleViper's Avatar
LittleViper is on a distinguished road
I know this is a old thread but I had to ask one question. Can you powder coat clear over the ceramic paint after paint has cured.
  #10 (permalink)
Old 06-08-2007, 06:43 PM
the last times I tried it cracked under the clear.
i was told to sand
paint
cure the paint
then powder clear and cure
but i never tried it
but vinyl stickers work , there was a thread about it a few days ago .
