Re: Questions about durability and outgassing
If you want chip resistance, the best advice I can tell you is:
1.Blast with Black Magnum or aluminum oxide media using meduim grit which leaves a very nice tooth/anchor for the powder to adhere.
2.use pretreatment chemicals ex: iron phosphate (steel) or zinc (aluminum
3.Clean/clean/clean and then some more cleaning and a good rinse making sure no finger prints are on the pieces being coated.
4. Insure proper cure times, this is a must.
5. Speak with a powder sales rep who can provide you with some strong heavy duty powder coating powders. There is a specific company that sells such powders.
To outgass properly, you must make sure you have given a very good rinse, you do not want any chemical residue left.
Place the items in the oven you want to outgass and turn the oven on, allowing the oven to preheak (soak) with the parts in, and get the oven to about 20-30 degrees hotter then the curing temp. Then leave the part or parts in there for a period of 30 mins after you confirm the parts have reached 420-450f. Doing this will always insure you have fully outgass any kind of trapped gas.
Aluminum is the most important metal when it comes to outgassing (Casts will always do this), some pieces no matter what will have outgassing present, if so buy outgass forgiving powders.
