+ Reply to Thread
Results 1 to 6 of 6
Thread: aluminum oxide media question
  1. #1
    Join Date
    Nov 2004
    Posts
    75
    Default aluminum oxide media question
    I am currently using garnett as a blasting media and it is VERY dusty, even with a vaccum. I am thinking about trying aluminum oxide. Is it dusty and will it work on blasting aluminum parts. thanks, any info would be great.
  2. #2
    Join Date
    Feb 2005
    Location
    belleville michigan
    Posts
    635
    Default Re: aluminum oxide media question
    no and yes. no its not as dusty and yes you can use it on aluminum. keep in mind though that it is more coarse than garnet and will roughen the surface up more so i would shy away if you want to shoot transparent colors unless you chrome base them.
  3. #3
    Join Date
    Nov 2004
    Posts
    75
    thanks, I think I am going to get a 50 pound bucket of it. The garnet is real dusty and I am worried about the silicosis from it. That and it plugs up my vacuum very quickly.
  4. #4
    I don't believe that garnet will cause silicosis. It has to do with silica based media.
    I currently use garnet and I don't notice much dust... but I have a dust collecter on my machine....maybe I just don't notice it.
  5. #5
    Join Date
    Mar 2005
    Posts
    200
    Want to talk about dusty... glass bead is ultra dusty. Will not use it again. Alum Oxide was much better in that regards.
  6. #6
    Join Date
    Nov 2004
    Posts
    75
    I just took out all of the garnet and put in 100 pounds of alluminum oxide, much better, I can almost leave my vacuum off. I strips alot better also. I will never go back to glass or garnet. thanks
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Something for you die hard polishers out there to chew on
    By thesound in forum Metal Polishing Questions
    Last Post: 12-03-2007, 12:16 PM
  2. Question about media blasting.
    By berad001 in forum Metal Polishing Questions
    Last Post: 02-04-2005, 11:29 PM
  3. Cleaning Oxidized Aluminum With Sand Blasting Media?
    By freematt in forum Other Metal Finishing Questions
    Last Post: 02-23-2004, 02:22 AM
  4. Media to mirror polish Aluminum in vibratory tumbler
    By hrothgar in forum Metal Polishing Questions
    Last Post: 07-26-2003, 11:32 AM
  5. Brand Newbie Aluminum Polishing Question
    By gdsegel in forum Metal Polishing Questions
    Last Post: 04-25-2003, 08:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
