1. Is there a way to PC the thin spots without sandblasting the wheel and starting over? 2. How can I get good coverage on two sides and top/bottom and all around the spokes? Thanks in advance for sharing your wisdom. Last edited by wolfpline; 10-20-2005 at 01:02 PM. |
spray them warm, to break down the faraday effect. You need a really good ground also. Since your gun does not have alot fof voltage it wont be an easy job to coat such wheels, even when I did a set of 20" Player wheels, the spokes didnt get fully coated and that with a pro gun and 2 coats, after 4 nice coats, they looked covered.
if you get the gun to close it will create more of a problem with the powder back ionizing, also quite possibly K.V fry if you already have a coat on there which you will just see the powder fall off and not stick. Allow the part to get to at least 200f and spray a nice even coat, make sure you have a fresh clean ground. You should focus on re-covering the entire wheel with another coat, otherwise you will get what looks like sand in certain areas because there wont be enough powder coverage to flow out smooth.
| where to buy aluminum wire | jtsuttle | Anodizing Questions | 1 | 03-21-2005 04:42 PM |
| Precision Wire Placement with a CDW | Fibergeek | Anodizing Questions | 4 | 11-25-2004 11:07 PM |
| wire rims | craigcraig | Powder Coating Questions | 3 | 07-03-2004 08:05 PM |
| Series 1100 Aluminum Wire | Fibergeek | Anodizing Questions | 2 | 01-27-2004 12:29 PM |
| wire welder for power source | elboriqua | Electroplating Questions | 2 | 11-04-2003 07:25 PM |
