I am rebuilding a ford 302 engine to swap into my ranger and I am thinking about ceramic coating the heads. Has anybody ceramic coated heads on an engine? Will I be better off using hi-temp powder? Would the cermaic aid in reducing underhood temps? Are there any negative effects of cermaic coating the heads?
Thanks Kyle |
I would say you'll probably be ok...BUT!!. Use caution when spraying, try to keep your film even and not too much build up. You don't want to create hot spots in the water jackets. Although the 302 is a very hearty engine It does have a tendency heat up very quickly under stress. This is usually not a problem but it could be if you have a few hot spots in your heads. I was a mechanic(ASE master mechanic) and built engines for many years and have seen very expensive performance engines overheat and grenade because someone decided it was a good idea to load it up with paint to make it look good. I've built and rebuilt engines as small as R/C car engines and as big as a diesel tug boat engine. It's my belief that you might be better served to ceramic coat the exhaust manifolds/headers to lower your underhood temp rather than the cyl heads. As an engine builder I would leave them alone I doubt you would see a significant benefit from ceramic coating your heads. In my opinion the potential risk outweighs the reward. If it were my engine I would ceramic coat the exhaust manifolds and VHT paint (thin) the heads and block. Again this is only my opinion.
One thing about ceramic coating the outside of the heads is that if you use a TBC coating, (thermal barrier coating) you actually keep the heat in the head, thus not allowing it to cool as it should, and that is not what one would want. Coating the head i would, and always do use, a heat dispersant coating, such as the Techline TLTD.
The Head and Block are 2 places you DO NOT want to keep heat in. Like someone has said in this thread if you ceramic coat anything do the headers.
If you want to add color then Powder the head, you will gain about 10-15 degrees by doing this. What I have done to help correct this is lowering the thermastat by that much. Did a ford Probe GT engine and ran teh stock t-stat and did not really notice any change in this motor. See attached image. Jim S...
Jim Shuster www.backyardpowdercoating.com Sold..... www.chrissys68mustang.com Hobbie www.photogserver.net Web Hosting. |
| Ceramic Coating WORKS! | Noob2PC | Powder Coating Questions | 24 | 10-25-2007 09:33 PM |
| Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! | Mcurtis7 | Used Items For Sale | 0 | 10-02-2005 02:18 PM |
| looking... yellow ceramic coating... | MikeWalker | Services Offered/Wanted | 2 | 09-27-2005 09:34 AM |
| Ceramic coating for wear | rclint | Other Metal Finishing Questions | 0 | 08-23-2005 10:23 AM |
| Ceramic Coating an Engine Block? | thesound | Powder Coating Questions | 13 | 02-19-2005 07:37 PM |
