FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
  #11 (permalink)
Old 11-05-2005, 05:39 PM
UnorthodoxCreations is on a distinguished road
Default Re: raised letter/object sanding technique
Originally Posted by jtagger19
that's agood idea
a Q-tip might work better than the finger
You have to watch anything that has cloth like a Q-tip or rag. One little strand of fiber can move around powder where you dont want it to.
  #12 (permalink)
Old 11-05-2005, 11:40 PM
speeddemonrodsteration's Avatar
I've tried Q-tips and they don't work as good as your finger- all the cotton strands start to fray and you end up touching the surrounding areas- the finger works best
Save the trees- burn Rubber!
  #13 (permalink)
Old 11-06-2005, 02:30 PM
corecoatings is an unknown quantity at this point
I was trying to post at work about the q-tip. It acts like a magnet. I was going to try and wet it but just used my finger.
  #14 (permalink)
Old 11-07-2005, 12:37 AM
tavo1765 is an unknown quantity at this point
its alot easier to first polish the letters out, spray and then place in the oven till it flows out. Let the piece fully cool, use a scotch brite pad or 2000 grit sand paper to remove the powder on the lettering and rinse off, do a full cure after that.
wet sanding sin Metal Polishing Questions 6 02-13-2005 08:18 AM
Object Size Jezella Electroplating Questions 4 01-29-2005 06:54 AM
Sanding squaredealer Metal Polishing Questions 3 09-05-2004 09:06 AM
technique for florescent/day-glo/neon colors strongtower Powder Coating Questions 5 05-12-2004 08:27 AM
CopyCad plating on 62 sq. in. object dhillebr Electroplating Questions 2 12-04-2001 12:21 PM
