I seem to be having a problem and its gotta be user error
Any ideas to speed up the process and keep it looking good? should I be using a small block with 220 sandpaper instead of the sponge? some of the lines I'm dealing with are 1/16" get to be a real pain to deal with. thanks for any help Chris |
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
why are you polishing after coating ? it a lot easier doing it first.
for raised letters here is what I do clean and blast the part I use a hand polisher called a MOUSE from SEARS I start with 220 ( 100 if it's too rough) then 600 then 800 then with a 3000 RPM hand polisher use black emery on sewn then white rouge on loose and you are set and won't take you over 20 mins from start to finish polishing the letters clean with thinner outgas tape out the letters with high temp green tape coat remove the tape |
now thats way too much work
thanks for the advise guys and I'll try out a sanding block this weekend. |
Chris:
If you're patient, try an x-acto knife. Just scrape away the top of the raised lettering. That's how I restored this 60 year old data tag: _Click for larger imageSean |
WOW! now that took some serious patience and time. HAHA I barely have enough patience to let my stuff cure fully, I doubt I'd ever be able to get through that. I gotta take my medicine any day I want to powder as it is. ADD sux
Blast your part and then powder it. Here is the trick, take your pointer finger, or which ever finger you feel most comfortable with, and slowly dab/drag the raised letters one at a time until the powder is removed. I did this with a valve cover after I did the candy red and it worked great.
| wet sanding | sin | Metal Polishing Questions | 6 | 02-13-2005 08:18 AM |
| Object Size | Jezella | Electroplating Questions | 4 | 01-29-2005 06:54 AM |
| Sanding | squaredealer | Metal Polishing Questions | 3 | 09-05-2004 09:06 AM |
| technique for florescent/day-glo/neon colors | strongtower | Powder Coating Questions | 5 | 05-12-2004 08:27 AM |
| CopyCad plating on 62 sq. in. object | dhillebr | Electroplating Questions | 2 | 12-04-2001 12:21 PM |
