Old 11-15-2005, 12:52 PM
machone's Avatar
machone will become famous soon enough
Default filling pits
I have a set of NEW calipers, bright silver finish (does not burn off). PC'd the inner bracket with lollipop blue & turned out great! Main body has pits in the casting (cast iron) I tried solder, but I can't get it to stick. What can I use to fill these pits? I'm trying to forego the chrome base.
mach
TSA Custom Metal Finishes
Live fast, Die sideways
Old 11-15-2005, 02:08 PM
machone's Avatar
Default Re: filling pits
As an afterthought, I think they're small enough that they won't show dark spots, could I use Liquid Steel or something similar?
Old 11-15-2005, 03:24 PM
Yep, JB Weld works good too..
Old 11-15-2005, 10:26 PM
Heavykote
I'm having a problem with pitting too! I have a rim and pitted all over. I even used lab metal to the crater area, but you can see the lab metal fill under the chrome powder. I outgassed and it didn't help. What do I do about this?
Old 11-15-2005, 10:44 PM
tinbender722 is an unknown quantity at this point
Send a message via AIM to tinbender722 Send a message via Yahoo to tinbender722
JB Weld is good up to about 600 degrees, and it sands fairly easily too.
Leo
www.tinmans.net
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!!!" ----- Unknown
Old 11-16-2005, 03:06 AM
machone's Avatar
Thanks guys!
I got some stuff from work "P.M.C. Super Quick Set". I'll try JB weld too, see which works best.
Old 11-17-2005, 07:50 PM
machone's Avatar
OK, Used the stuff from work, let it set & gave it a light wire wheel to match the texture. Used carb cleaner to clean it,(read that somewhere in here) heated it at 300f to burn it off. I coated it, cured it, & came out with fish eyes. DOH! Lightly sanded it with 200 grit just to smooth the fish eyes, recoated it, cured it, came out GREAT! The only thing was(back to the pits) it did show the dark spots. Not very noticeable, but they're there. SO.... if you have to fill pits when using translucent colors, ya gotta put the base coat on it! As a side note, blasted & cleared an old rotor I had laying around, makes a killer display base! One of these days we'll get a digital camera!
mach
  #8 (permalink)
Old 11-17-2005, 08:00 PM
sswee's Avatar
Moderator
Something you might try also is when you use brake wash or any solvent, hang the part in the oven at around 150* for 10 to 15 minutes to make sure all the slovent is out of the pores. I have had brake wash cause fisheye before I started drying in a warm oven.
SS
  #9 (permalink)
Old 11-17-2005, 11:14 PM
pickleboy's Avatar
brake clean instead of carb clean. carb clean has tolulyene(spelling?)in it and it leaves a residue that is hard to get off. brake clean works good though. also if you have the safety gear mek works great but it pretty bad stuff.
  #10 (permalink)
Old 11-18-2005, 03:14 AM
machone's Avatar
sswee, did that, at 300 for about 10 minutes. Think the problem was the Gumout instead of Brakleen (copyrights, of course). I'll stick with the Gumout, don't want "bad stuff" in my basement!
Thanx for the info bothofyas!
mach
Filling pits fly Plating Pot Metal 5 09-15-2005 10:33 PM
Filling pits in steel in preparation for nickel plating pastorclyde Electroplating Questions 2 07-13-2005 10:50 AM
filling small pits with acid copper danderson Electroplating Questions 2 08-25-2004 08:55 AM
Filling pits in aluminum casting? johnshenry Other Metal Finishing Questions 5 05-11-2003 05:50 PM
Filling In Gouges mitch_vinton Metal Polishing Questions 4 04-17-2002 05:10 PM
