Buy One Get One Free Powder Coatings
Until July 31st
BUY ONE POUND - GET ONE POUND FREE
(Same color only. Limit 1 Free Pound, Per Color, Per Customer)
- Enter 2 in the quantity field
- Pay the 1 Pound Price for 2 Pounds
Offer Valid On ALL powders, through 7/31, US Customers Only
View Powders Now
Old 12-05-2005, 09:06 AM
mtnbiker is an unknown quantity at this point
Default bead blasting - vacuum to keep dust down
What kind of vacuum are you guys using to keep the dust out of the blast cabinet?
The shop vac I have hook up is just too much. I can only turn it on for a second or two when I am not blasting in order to clean out the dust fog. If I leave it on while blasting, I suck out too much media.
Thanks
Old 12-05-2005, 09:12 AM
sswee's Avatar
Moderator
Default Re: bead blasting - vacuum to keep dust down
What size cabinet and where on it is the vacuum hooked up?
Old 12-05-2005, 09:14 AM
I guess that would have helped.
It is just a small desk top blast cabinet. And the hose is hooked up near the top left side.
Old 12-05-2005, 09:58 AM
machone's Avatar
machone will become famous soon enough
I put a small piece of screen over mine, keeps the sand in but sucks the dust out.
mach
TSA Custom Metal Finishes
Live fast, Die sideways
Old 12-05-2005, 12:45 PM
kcrails
I'm using a 6.5 HP shop vac on mine, but then again I have a pretty big cabinet. If I remember right, 40x28x36. On a benchtop unit like that, I'd look at one of the small shop vacs, Home Depot has one on their website for $27.00. Also, it's connected to the cabinet up at the top rear corner. Hope this helps.
Old 12-05-2005, 12:49 PM
Yeah... I guess I just need to stop in at Home Depot or something and check out the little shop vacs.
Old 12-05-2005, 03:56 PM
I use an upright carpet vacuum with the hose attachment. Most people throw them out because the brush stopped working. FREEBIE
  #8 (permalink)
Old 12-08-2005, 09:59 PM
BerkelUSA's Avatar
BerkelUSA is an unknown quantity at this point
Send a message via AIM to BerkelUSA Send a message via MSN to BerkelUSA Send a message via Yahoo to BerkelUSA
Canister Vac!, one of those old-skool monsters the ol' ladies toss out (rarely), usually found at a yard-sale.. Problem is sometimes finding bags because they are so old.. lol, Try making a burlap-bag IF you cant find one..
Mine uses a BIG shop-vac with the larger hose, The side of the cabinets usually have a 3" or so hole that is also identical to the hole in the side of the vac itself.., In other words IF you can get another plastic end from a junk one it pops right in on the cabinet and at the vacuum.. No more duct-tape!
My cabinet is the Cyclone with the same dimensions you listed.., Does yours also have a door and open clam-shell??
Another way to eliminate most of the dust is trying out that new stuff called Star-Blast.. (titanium sand), They say that it is "dust free"....
Along with a bigger Vacuum be sure that the air vents at the other end are at least twice the size of the hole at the other end, This way it has no struggle in sucking the clean air IN.., I have HUNDREDS of these micro-mesh screens to get rid of that work perfect screwed to the side of any home-brew or industrial made cabinet...
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
  #9 (permalink)
Old 12-08-2005, 10:02 PM
BerkelUSA's Avatar
Another one is those bag-less Cyclone? Tornado? vacs, Just remove the belt from the brush.. and any media it sucks-up you can pour back in the tank after it's been screened..
  #10 (permalink)
Old 03-09-2006, 07:57 PM
rx7carl
I used a shop vac and within a year the motor seized. The dust is so fine that it gets past the filter and in the bearings. I bought a small dust collector from Harbor Freight. It seems to work ok. Right tool for the right job.
Sand or bead blasting Q sorry, im a noob just starting Paintbalaguy Other Metal Finishing Questions 3 07-19-2005 09:20 AM
bead blasting powder coat ?????? showroomexpress Metal Polishing Questions 2 01-15-2005 08:11 PM
Surface Area pre/post Bead Blasting kickn Anodizing Questions 2 10-26-2004 05:11 PM
Bead blasting mask. GramSlam Other Metal Finishing Questions 6 03-24-2004 09:37 PM
Respirator failed while blasting with glass bead... skiddz Powder Coating Questions 5 01-17-2004 01:36 PM
