+ Reply to Thread
Results 1 to 9 of 9
Thread: powdercoating over factory powdercoating
  1. #1
    Default powdercoating over factory powdercoating
    Bear with me as I am new to PC I am looking to powdercoat aluminum wheels that came from the factory with with a silver podercoat and clear coat. Can I powdercoat over this or do I need to strip everything off or maybe just the clear coat. If I just need to take off the clear coat, how do I do that? I have a large blast cabinet if that helps. Thanks in advance.
    Share with Facebook
  2. #2
    Join Date
    Jul 2004
    Location
    New Milford, PA
    Posts
    210
    Default Re: powdercoating over factory powdercoating
    To get the best results always go back to bare metal.
    If you have the cabnet to blast then go for it...
    Jim S..
    Share with Facebook
  3. #3
    Quote Originally Posted by hvac36
    Jim S..
    The cabinet will never strip that off. I have tried will alum oxide and the wheel laughed I stipped one with aircraft stripper but that was way too much work. The rim that I stripped was already powdercoated black (by someone else) over the factory powdercoating and clear coat. It seemed to have very good adhesion and good finish.
    Share with Facebook
  4. #4
    Join Date
    Jul 2004
    Location
    New Milford, PA
    Posts
    210
    Here is how I do it.
    1 Use Stripper ( cover with plastic wrap).
    2 Scape off what you can..
    3 Use Stripper again same as #1
    4 rinse parts.
    5 Sand Blast with slag med..
    I will never Powder over some one else work, as you have no idea of the base coat..
    This is how I do it and I have never had a part fail...
    This is my advise you can use it or not...
    Jim S..
    Share with Facebook
  5. #5
    thank you. I will try the plastic wrap. The stripper is not working to it's full potential beacause of the cold temps in the garage. The only reason that I would consider trying to coat over the existing finish is because it is a factory finish.
    Share with Facebook
  6. #6
    Join Date
    Jul 2004
    Location
    New Milford, PA
    Posts
    210
    Just so you know there are 2 types of Air Craft Stripper ( I like that word ) )
    The first 1 is Air Craft Remover,
    the other is Air Craft Remover Low Odor the 2nd does not work worth a darn.
    Jim S...
    Share with Facebook
  7. #7
    Thanks for the tip. The stuff that I have is the low odor. Any idea where I can get the other one?
    Share with Facebook
  8. #8
    Join Date
    Feb 2005
    Location
    belleville michigan
    Posts
    635
    you might be able to find it at the same place you got the low oder. just ask for the regular aircraft stripper. if not try auto parts stores or auto paint supply stores
    Share with Facebook
  9. #9
    Join Date
    Jul 2004
    Location
    New Milford, PA
    Posts
    210
    I purchase mine from and Auto Body Supply store..
    Something like 25 a gallon..
    Wear a mask or make sure you have plenty of ventilation!!!!!!
    Stuff will knock you over... lol...
    Jim S...
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Websites For Powdercoating
    By CaptainChauncy in forum Powder Coating Questions
    Last Post: 10-16-2005, 09:09 PM
  2. My first day powdercoating
    By UnorthodoxCreations in forum Powder Coating Questions
    Last Post: 10-07-2005, 12:48 AM
  3. How would you go about touching up powdercoating?
    By Heavykote in forum Powder Coating Questions
    Last Post: 07-03-2005, 09:19 AM
  4. Can i use a big gas oven for my powdercoating needs?
    By JasonH in forum Powder Coating Questions
    Last Post: 05-21-2005, 11:15 PM
  5. Getting Into Powdercoating and Need Some Help ... Please
    By Benny10 in forum Powder Coating Questions
    Last Post: 10-22-2004, 08:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
