-degrease the part -media blast the part -dust off with shop air -clean with prep-sol -coat the part -and bake Am i missing anything? Somethings i read make it sound like the prep is much more involved but others suggest the above. Thank you, Joe |
That's it in general. I would recommend also an IR thermometer. The cure time starts when the part reaches the cure temp. and that can vary in time with material and mass. It's not a bad idea to make some sort of spray booth. I have pics of mine in the album, that has worked good for auto parts. It's based on others seen here. I'd also get 1lb of several colors. Once you get started, you'll want to PC everything. SS
http://www.caswellplating.com/powder/ir_therm.html |
Thanks for the tips guys. Luckily I already own an IR thermometer, it looks like they went down in price, I paid almost $200 several years ago. So basically I would use the IR thermometer to see if the part has reached curing temperature? This is a more accurate method then simply seeing if the powder has begun to flow?
thanks again Joe |
I've been doing some reading on making a spray booth. I'm thinking of making one to place on top of my oven. About 30"x30"x24", 5 sided. I'm going to make it out of MDF, and paint the inside. I am going to use a bathroom vent fan on the back wall. I plan on venting the booth to the outside. I was thinking of placing a piece of wire mesh (chicken wire) over the vent grill. I will also make a hanging rack. Should the rack, wire mesh, and part to be coated all grounded through the grounding plug on the pc unit? Or do you use a house ground? Is there a difference?
thanks -Joe |
I put a J bolt in the top with a swivel clip on it and use a piece of dog chain to vary the hieght of the part. A roll of hot wire fence and a handful of S-hooks from the hardware store come in handy for hanging parts. I clip the ground alligator clip on the J-bolt. An 18" flourescent enclosed light in the top also helps. SS
Any powder or dust in a high enough concentration is explosive. That being said, I doubt you'd kick up enough dust to get a bang.
Filter the exhaust air before it hits the fan, filters are fairly cheap and your fan will last longer. Size your fan so you have 100Cfm for every square foot of opening on your booth. That should keep the dust contained... A speed control on the fan would be nice too. IMHO |
| Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! | Mcurtis7 | Used Items For Sale | 1 | 02-19-2009 02:39 PM |
| powder coating over powder coat? | corybarta | Powder Coating Questions | 6 | 08-21-2006 09:15 AM |
| new to powder coating | pickleboy | Powder Coating Questions | 0 | 06-23-2005 11:12 AM |
| New to powder coating ? | customandsound | Powder Coating Questions | 0 | 06-21-2005 03:00 AM |
| Powder Coating Gun | getastro | Powder Coating Questions | 4 | 09-28-2003 12:03 PM |
