well here it goes, i have a nordson versa spray gun. it has worked fine up to a few weeks ago when i noticed it was getting harder to get the powder to adhere. it sprays fine but the powder will not cling to the parts.when i pull the trigger the reading is in the negative side, should it be a positve charge?please help me i have been going crazy tring to figure this out. thank you
I've been ussing nordson for almost 2 years
I'll try and help you out at my best with a nordson ground is not such a big deal as hobby guns but still you need bare metal contact is it getting harder for the first coat or second coat what are you atomiser and flow settings ? |
i have bare metal contact, it is not covering when ever i use it. there is like a little electrode in the tip of the gun, do these go bad?i keep adjusting the settings to see if anything changes but nothing has worked. thanks
it could be a couple things
first thing you have to check is the GND ( ground) but since you already said this wasn't it lets scratch that. second thing can be the resistor unfortunatedly the only way you can test it is with an AMPMETTER wich will cost you like $200 or you can buy a new resistor holder kit for like $60 if the resistor is bad it won't charge the powder and there for won't stick to the part specialy second coats ( candy colors) third is the pump the old cooper pumps wear out with time and you slowly have to keep adjusting the flow and atomiser settings untill there comes a time when the settings are so high the same powder repels the new powder of the parts you should have around 30psi atomiser and 20psi flow forth and in a worst case it might be the multiplier wich will cost you like $1200 and is only sold by nordson them selfs to me it sounds like a bad resistor you can get the manual here http://emanuals.nordson.com/finishing/index.htm and you can buy parts here www.azpowder.com/ |
| Flash Copper Problem | gwjohnso | Plating Pot Metal | 12 | 02-28-2007 12:41 AM |
| Anodizing Problem???? | Cyberave68 | Anodizing Questions | 3 | 03-31-2004 03:03 PM |
| Nitric Acid/Desmut problem....Help | Easttex | Anodizing Questions | 1 | 02-19-2004 11:59 AM |
| i 'm in need of help.....fast!!! | motoc | Electroplating Questions | 1 | 01-25-2004 06:59 PM |
| BEWARE!!! Problem Plating Car with Metallic color paint! | GoldiesPlating | Electroplating Questions | 0 | 08-29-2003 10:29 PM |
