What do you guys use to remove oxidation from cast aluminum? I have an old school Turbo Dodge valve cover I'm trying to clean up to coat and there is oxidation all over it. I sandblasted it, tried using a scotchbrite pad, sanded it with 220 grit sandpaper but there is still oxidation in the metal. Will this show through if I coat over it? I'm guessing so, that is why I'm looking for other options. I do have a couple other things I'm going to try but any help would be appreciated. Thanks,
Jason |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Problems w/ cast aluminum | sthomag | Metal Polishing Questions | 2 | 02-03-2006 02:41 AM |
| Polishing cast aluminum | turbohardtop | Metal Polishing Questions | 26 | 07-05-2005 11:10 AM |
| Cast Aluminum | scocklin | Anodizing Questions | 5 | 12-04-2004 12:38 AM |
| Removing the chrome surface from aluminum based auto trim | jbashaw | Metal Polishing Questions | 6 | 10-01-2003 11:20 PM |
