Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
  #11 (permalink)
Old 05-01-2006, 02:44 AM
zgcfab is an unknown quantity at this point
Default Re: Extreme Chrome with Clear Coat How to...
can you use extrem crome on a v8 head?
  #12 (permalink)
Old 05-01-2006, 07:09 PM
hvac36's Avatar
Moderator
hvac36 will become famous soon enough
Send a message via AIM to hvac36
You can use the all powders on anything that will not exced 400 degrees. So yes but you may loss a little around the exhaust ports.. But not much that I ever noticed..
Jim S...
Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
  #13 (permalink)
Old 05-03-2006, 07:24 PM
thanks for the info want to do my lt1 heads
  #14 (permalink)
Old 05-04-2006, 09:08 AM
Timmer is on a distinguished road
What sort of price would you charge on doing the extreme chrome and clear on 4 atv rims? Any input would be great.
  #15 (permalink)
Old 05-05-2006, 01:18 AM
i like to charge like 40 and hr to do the stuff i do at home covers eletric bill and labor and do you have to clean the parts 1st
4 rims would be like 120 150 some ware like that
erik
  #16 (permalink)
Old 05-14-2006, 03:21 AM
mx3twinturbo is on a distinguished road
well i just got donw doing a few parts,
and sprayed the Extreme chrome, cured at 395, for 15 min, let cool then sprayed a thicker coat of clear then cured for 20 min,pulled it out and the sweet chrome had turned in to a mirror silver or the like,
should i make sure i fully cure the 1st coat? what did i do wrong any input would be great
thanks,
Jesse
  #17 (permalink)
Old 05-14-2006, 01:58 PM
cdaeme's Avatar
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
With the chrome powders you must fully cure the chrome powder before the clear top coat. As Jim stated in the first post let the extreme chrome cool all the way down to room temperature the coat with clear. I have done this with super chrome and exterme chrome with great results. The silver effect is definately from under cure I have done the same thing myself.
JASON
  #18 (permalink)
Old 05-14-2006, 09:52 PM
cool, thanks, i am going to retry it now, i will post some pic if any one wants,
well lets see if it turns out right this time
  #19 (permalink)
Old 08-20-2006, 12:48 PM
mtnbiker is an unknown quantity at this point
Does any one clear work better than another?
  #20 (permalink)
Old 08-23-2006, 01:05 AM
Torchred73 is on a distinguished road
Ok, I got my pound each of Xtreme and Super Clear in the mail today and am ready to shoot some parts. However, when I read the write-up by Hvac36, it says "Now Cure at 375 for 30 mins,", but the can of Xtreme says 392 for 30 min. If I bake at 375, will it cure or is this reduced temp part of the "Magic" to prevent the clouding and greying?
Just read the can of clear and it also says 392 for 30. So.... heat the Xtreme back to 150, coat, and then to "the required time" for clear? 392 or 375? Doh!!! (scratching head)
BTW thanks for the write-up Hvac36, I'm sure it has helped many get the results they wanted! I, on the other hand, am easily confused and slow!!!
Later
cleaning brass before clear coat. ovrundr Metal Polishing Questions 5 08-31-2005 01:45 AM
supper chrome craking under clear coat clintlawrence Powder Coating Questions 6 04-05-2005 09:05 AM
Clear coat problem sportster883r Powder Coating Questions 3 11-21-2004 05:52 PM
Is it required to clear coat chrome (Reflectra)? remotestartdepot Powder Coating Questions 1 05-11-2004 10:10 PM
Clear coat chrome? merse1 Powder Coating Questions 2 04-13-2004 11:38 PM
