Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Old 02-16-2006, 12:25 AM
hvac36's Avatar
Moderator
hvac36 will become famous soon enough
Send a message via AIM to hvac36
Lightbulb Extreme Chrome with Clear Coat How to...
This is the write up I promised back around Christmas but due to family issues I was not able to get to it...
The 2 Images attached are done with extreme chrome and super high gloss clear coat.
Image 0504 is just Chrome:
Image 0506 has teh clear coat on it..
Now the How To Part of this post..
Do your prep as normal,
Apply Chrome as normal BUT applying only enought to coat and not over coat you want a good thin layer. Now Cure at 375 for 30 mins, yes this is after it has come up to that temp ( the part not the oven ).
After curing let part(s) cool to room temp this is very important that it is room temp!!!
Now reheat part to 150 degree's +/- 10% remove from oven then clear coat for the required time, No more no less.
So far I have used over a pound of powder each and have turned out the same results each and ever time.. With very very little to no cloud effect..
Jim S...
Extreme Chrome with Clear Coat How to...-0504.jpg   Extreme Chrome with Clear Coat How to...-0506.jpg
Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
Old 03-24-2006, 12:07 PM
2Hyper is on a distinguished road
Default Re: Extreme Chrome with Clear Coat How to...
Can someone talk more about clear coat? Is it a powder also? Do you spray and bake the color, then spray and bakee the clear after? Or is it a liquid clear?
Old 03-24-2006, 05:25 PM
BLOWNTRC5 is on a distinguished road
The clear is a powder that you spray and bake. I just got a few lbs. of the super high gloss clear and it looks killer. My customer was VERY happy!
Doug
Old 04-01-2006, 01:16 PM
palmbeach's Avatar
palmbeach is an unknown quantity at this point
will this work for the near chrome also and do you use a thick clear coat
Old 04-12-2006, 12:40 AM
hvac36's Avatar
Moderator
The method I posted above will only work with the Extreme. The Super and Near Chrome will turn a grayish tone..
Jim S...
Jim Shuster
Old 04-16-2006, 10:59 PM
red911's Avatar
red911
Hi Jim,
How do you get the clear to attach itself, with the 150 degree heat? I have been thinking a lot about how to powder coat the color - Artic Ice in my case, then recoat with Clear without grinding a place in the steel wheel to catch the anode for the gun. Does the heat catch the clear powder coat so I don't have to have a "colorless" area where I attach the alligator clip?
Thanks in advance, Tom
Old 04-17-2006, 10:49 AM
zgcfab is an unknown quantity at this point
what will happen if i dont clear coat the exstream crome
  #8 (permalink)
Old 04-18-2006, 12:23 AM
cdaeme's Avatar
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
It's easily scratched, and it will oxodize over time.
Jason
www.autocyclepc.com
  #9 (permalink)
Old 04-18-2006, 11:24 PM
red911's Avatar
red911
Hi Jim,
I powdercoated a 15 inch rim last night with Artic Ice and Clear. First, I baked the Artic Ice and baked that in my kitchen oven that I have moved into the garage. I had to spray the inside then the outside and bake. Then, I pulled the rim out and let the temp drop to 150 degrees and inverted the rim, as I baked it outside, or shiney side out and up on the oven's rack. I powdercoated the inside first and turned the rim over and got the rim back up to 150 degrees and then found I could attach the ground wire and get the powder to draw toward the rim, so I may have answered my own question.
That is to reconnect the ground wire and shoot away as the powder will stick whether or not the temp is 150 degrees.
Am I correct.
  #10 (permalink)
Old 04-19-2006, 09:17 AM
hvac36's Avatar
Moderator
Tom,
Yes you are correct. You need to attach the ground everytime you shoot the powder...
Jim S...
Jim Shuster
cleaning brass before clear coat. ovrundr Metal Polishing Questions 5 08-31-2005 01:45 AM
supper chrome craking under clear coat clintlawrence Powder Coating Questions 6 04-05-2005 09:05 AM
Clear coat problem sportster883r Powder Coating Questions 3 11-21-2004 05:52 PM
Is it required to clear coat chrome (Reflectra)? remotestartdepot Powder Coating Questions 1 05-11-2004 10:10 PM
Clear coat chrome? merse1 Powder Coating Questions 2 04-13-2004 11:38 PM
