When burning off powder what temperature can the following items tolerate without causing damage to the part?
1. Stock valve covers 2. Motorcycle frame 3. Cast aluminum parts 4. Steel wheels I do have access to a permitted industrial burn off oven. Thanks in advance for the help. |
Thanks for the response guys. Even though I use the burn off oven every day to remove epoxy from A36 steel I was a bit hesitant to use it on other items. Present setup has the burn chamber running at 600 degrees F for two hours then ramping up 50 degrees every two hours until a 750 degree burn is completed. What comes out of the oven is ready for a quick blast and another round of powder. Items burnt are hanging fixtures for an automated line. I had a guy drop off some junk parts from a old demolition car to try out. Think I'll see what it does just for the heck of it but won't consider using it on any structural or support items like wheels or frames. Thanks for your input.
the stock valve covers are the only think i would try. the wheels, and motorcycle frame definately not due to chance of removing temper and makeing them weak. as for the aluminum it will most likely destroy the heat treat and make them brittle.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
| high temp- how high? - will it burn? | mtnbiker | Powder Coating Questions | 6 | 09-27-2005 12:47 AM |
| Dealing with thermal shock / high temps | AresP | Electroplating Questions | 0 | 08-13-2004 09:08 AM |
| Longer times & Lower Temps | Noob2PC | Powder Coating Questions | 12 | 07-29-2004 11:08 PM |
| 700 DEG. TEMPS | turch | Powder Coating Questions | 2 | 02-03-2004 12:04 PM |
| Curing Times and Temps | Fireblade | Powder Coating Questions | 5 | 05-22-2003 09:17 PM |
