Old 03-08-2006, 09:06 PM
callmej75 is on a distinguished road
Send a message via Yahoo to callmej75
Default Running 2 regulators?
Is it ok to run 2 regulators on a compressor? I have the regular regulator on the compressor but I also have an oil/water separator that also has a regulator on it too. Not sure if I should hook up both or what. I believe the regulator on the air compressor goes beyond 70psi but the other regulator with the separator only goes up to 70psi max. I am getting some really small fisheyes on my test panels and was hoping this would be the fix.
Old 03-08-2006, 11:13 PM
sswee's Avatar
Moderator
Default Re: Running 2 regulators?
It will not hurt to run a second regulator inline.
Old 03-09-2006, 04:45 PM
kchotboat
I have three water separator on my set up. One in the basement right off the compessor, the next one right when the airline gets in the garage and then one at my booth. two of the three have regulators and a small one at the gun.
Running 2 rectifiers together?? Is it possible? jeff0628 Electroplating Questions 7 04-16-2005 01:48 AM
Zinc plating on running seal surface? Broke Electroplating Questions 1 12-06-2004 02:52 PM
up and running elton10 Anodizing Questions 4 04-02-2004 10:02 PM
