I am interested in finding out if powder-coating could be a solution to a finishing problem that I am having. I have never done any powder coating so I a complete novice.
I am trying to refinish a watch dial (from a wristwatch). So this is a very small part, and I need a very clean, smooth finish. The problem is that there are raised hour markers on the dial, and these cannot be removed. But I don't want them painted (I only want the flat part of the dial to be painted). I could try to mask the raised markers and then paint the dial, but that will be hard because they are so small. So one thought I had would be to dust the surface of the dial with powder-coating powder. If I kept the dial completely level, I could (maybe) make sure that none of it got onto the raised markers, and that it only sits on the dial surface. Then I could bake it. Will this work? My guess is that I would have to be very careful not to shake the dial as it is going in the oven, etc. But theoretically can it work? Also, can I do this in my kitchen oven (for such a small part) or will that cause damage or a big stink? I don't want the wife mad at me over this. Thanks for any guidance you can suggest. |
if I where to do it
it would have to be a solid color ( single stage) a 2 coat color would be to thick ( candies) a hobby gun might work but I would use a high end gun at 80-100Kv to get very thin even coat and then clean the raised letters with a hobby knife or something then cure it would work, it might get you a few tries but it would work. if you are refering to just dust the surface with no gun it will not work , cuz you will not get an even coat and the powder will not stick to the surface |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 08:37 PM |
| Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! | Mcurtis7 | Used Items For Sale | 0 | 10-02-2005 03:18 PM |
| Powder Coating (Chrome) Question... | TCalYen | Powder Coating Questions | 3 | 05-12-2004 12:24 PM |
| Non-paint powder coating | dshepherd | Powder Coating Questions | 6 | 01-26-2004 12:49 PM |
| Newbie questions about Powder Coating | thirdlife | Powder Coating Questions | 3 | 12-16-2003 06:09 PM |
