FREE POWDER COATING SYSTEM
I'm using a high gloss TGIC black and noticing small micro scratches in the finish product. These scratches develope after wiping lint or dust off coated parts. Even if there is nothing on it you can take a soft towel and this will still leave scratches. Manufacture recommended cure cycle is 10 min. @ 400 degrees. I don't start the 10 min. cure cycle until the part reaches 400 degrees. Iv'e even doubled the cure time to 20 minutes and still get the same result. Solvent rub test has shown coating to be fully cured. I have heard that high gloss blacks are prone to these scratches. Is this true? With these being motorcycle parts, is there a diffirent type of powder that should be used? In some cases the powder must put up with high engine temps. Any comments welcome.
Thanks for the comments and the welcome Pickleboy.
Manufactures data sheet calls for the 10 minutes @ 400F. Sprayed a few test panels today for DSC testing from powder manufacturer. Can't scratch the coating with a fingernail any more than with a towel. What about a clear coat over the black? Any potential delamination or clear discoloring issues to consider? |
wamontgomery the solvent test is done after a full cure cycle to test the finish. on a full cooled part using a soft cloth and acetone or mek on the cloth rub the finished part in the same spot for about 30-50(opinions vary on this) strokes. if the powder is properly cured it will not color bleed on the cloth and will not fade. if it does it was not fully cured. hope this helps.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
As Pickleboy stated, I've heard of a number of different methods for solvent tests. For poly's I used a 10% MEK/90% Xylene mix for 50 double rubs. No effect on the coating. After that I tried MEK alone. Usually only use that on epoxies but it didn't cut through the TGIC. It did soften the surface but if it wasn't cured I would have expected it to go down to the part or at least make a mess.
Think I will try Pickleboy's suggestion of waxing before any handling. I have waxed after the fact and it does help hide. Anyone tried a different type of gloss black powder that resisted scratching but was still had good weathering properties? |
| Help polishing out scratches on chrome. . | Hantra | Metal Polishing Questions | 5 | 07-11-2005 05:11 PM |
| Removing Chrome Scratches | dwest | Metal Polishing Questions | 2 | 11-29-2004 12:15 AM |
| SCRATCHES | clockman | Metal Polishing Questions | 5 | 06-08-2004 08:18 PM |
| Stainless steel Scratches | SP4SPD | Metal Polishing Questions | 7 | 01-12-2004 08:42 PM |
| How Do I remove tiny, light scratches from Aluminum? | chem_man3 | Metal Polishing Questions | 17 | 03-04-2003 11:46 AM |
