Looking around on the net, I found that magnesium melts at 650°C/1202°F. One site says: The ignition temperature of massive magnesium is very close to its melting point of 650 degrees C (1,202 degrees F). (See Table 2.) However, ignition of magnesium in certain forms may occur at temperatures well below 650 degrees C (1,200 degrees F). For example, magnesium ribbons and shavings can be ignited under certain conditions at about 510 degrees C (950 degrees F), and finely divided magnesium powder can ignite below 482 degrees C (900 degrees F). Has anyone powder coating ever had a problem with magnesium catching fire? Come to think of it, it would be nice to pc my moms wheels. She's got a '66 MkII Sunbeam Tiger that has some awesome Halibrand mag wheels. Clear pc would sure protect them from the elements. |
I've powdercoated some small scooter rims that were magnesium. They turned out good, but whenever other's want something magnesium done, I turn them down. It's not worth what could happen. In other words, I won't do magnesium again.
ShelbyCSXT, I've done quite a few motorcycle parts marked magnesium with no problems. Check the album . My knowledge of magnesium fire hazards coincides with the info you posted. With 20+ years in a machine shop, I worked with one guy that his pevious employer no longer had a shop due to a magnesium fire. It was caused by someone not doing their job correctly and ignited a machine full of shavings. I haven't had any problems machining it. I don't have a problem with PCing it. I wouldn't advise putting it into a burnoff oven or trying to tig it. Magnesium fires are nasty with no doubt. This is my opinion from my own experiences. If someone has any doubts or hesitations, then they should not do it. Better safe than sorry. SS |
Don't know where you're at hulk, but Magnesium wheels are illegal to use in the USA. They banned them because they are EXTREMELY flammable. Be careful when curing.
i m living in province de quebec canada never heard about restriction on magnesium wheel up here the wheels are coming from a Corvette and the owner told me they are original wheels from gm i pretty sure they will be no problem a 450 f but if somebody had a bad experience whit magnesium let us know |
And unless you are sanding the magnesium and there is a fine dust all over the place... I cant see them 'catching fire'. |
| Magnesium??? | KZjim | Powder Coating Questions | 5 | 01-23-2006 09:58 PM |
| Has anyone Powdercoated Magnesium? | Heavykote | Powder Coating Questions | 21 | 08-13-2005 10:44 AM |
| Coloring/finishing Magnesium Bronze | homydog | Other Metal Finishing Questions | 6 | 04-03-2005 03:03 AM |
| Polishing Magnesium | etyrrany | Metal Polishing Questions | 0 | 11-14-2003 09:57 AM |
| magnesium? | excess enemy | Electroplating Questions | 4 | 12-04-2002 09:39 AM |
