I've just done a few trials with our epoxy FASTSTEEL. This material comes in a 'tootsie roll' bar, that you just cut off the amount required. Roll it in you hands to mix it, then place it onto a roughed up/bead blasted surface, and press in firmly.
To shape the material, simply press with a wet finger (spit is good!) and work the material in to smooth it out. Sometimes lacquer thinner will also help smooth it out. Faststeel can be sanded or ground, but it is very tough, not like Bondo. If you do a good job of placing the material, you can powder coat it while it is still soft. The 400 deg temps will rapidly cure the resin, and this 'post cure' will actually enhance its strength by some 20% or more.
And, what about recoating after it had already been hardened? |
It will coat even if it has hardened. It's very tough, you'll like it.
What is the temp rating on the product? I sometimes will run a part thru 2 or 3 times due to coating... I know the lab metal will only pass thru once ( if your lucky) but must be 100% cured or it will out gas.. Jim S...
Jim Shuster www.backyardpowdercoating.com Sold..... www.chrissys68mustang.com Hobbie www.photogserver.net Web Hosting. |
Run it through as many times as you like. It won't outgass.
It will harden to cope with the situation it's put into. Except a naked flame, then it will burn.
| metal repair prior to coating....? | Dermagrfx | Powder Coating Questions | 7 | 09-07-2005 09:05 AM |
| Spot repair hard anodizing? | remotestartdepot | Anodizing Questions | 1 | 01-30-2005 12:57 PM |
| Powdercoating over powdercoat or unknown material. | jblack223 | Powder Coating Questions | 3 | 07-28-2004 01:26 AM |
| Custom oven material and heating element help needed | DarinReiss | Oven Building Forum | 13 | 12-27-2003 09:24 PM |
| how do i know what type of blasting material to use? | 11111111 | Powder Coating Questions | 26 | 11-28-2003 12:34 AM |
