hi guys, i purchased a low cost powder machine and today was my first time powder coating with it. i had a couple problems, nothing major, but i have some questions and hope you guys can help.
1 the powder was really erratic, sometimes none or hardly any would come out, other times when you pulled the trigger it would pour out the end, what am i doing wrong? 2 if i have polished aluminum or SS do i have to do anything to it besides cleaning it to get it to adhere properly? if you scuff it and clear it do you lose the polish effect? 3 it didnt seem to me that the powder was flowing to the part too well, is it supposed to be noticeable or do you normally lose twice as much powder as gets on the piece? thanks in advance, will be doing more tomorrow. |
upersleder:
1. This happens alot with the hobby guns. I find tapping the bottles while shooting helps. 2.Yep just clean it good and shoot it. For translucent colors that is. Regular solid colors should be scotchbrited and then coated. 3.Check your ground, also check the transformer unit to make sure it is working. Good luck. Ken |
hope this helps
1 = use 20 PSI going to the gun so that when you pull the trigger you get around 15 psi , adjust the bottom plastic screw till you get the right amount of powder and you might want to shake the gun in a small circular motion while shooting 2 = anything done to a polish surface will be seen after clear is applied clean it as best you can , outgass and coat 3 = powder always has some wavi finish and it shows up more with hobby guns , you might want to check your ground too. and for second coats always use the 150 rule let part cool to 150 degres then coat , you will never have any problems Last edited by jtagger19; 04-25-2006 at 10:33 PM. |
Cool uper, (spelled yooper down here
mach
TSA Custom Metal Finishes Live fast, Die sideways |
| Another newbie - surface area to anodizing time? | kumaichi | Anodizing Questions | 9 | 11-07-2004 03:46 PM |
| distilled vs. tap water and anodize time too short | blackcote | Anodizing Questions | 20 | 07-12-2004 05:44 PM |
| Anodizing tank time | usao | Anodizing Questions | 12 | 03-27-2004 03:06 PM |
| Color depth vs. anodizing time | NeoMoses | Anodizing Questions | 17 | 02-03-2004 09:06 PM |
| Top coating, one more time | getastro | Powder Coating Questions | 1 | 07-22-2003 08:17 PM |
