I bought some tropical orange (2lbs "2-1lb cans") and some chrome (2lbs "2-1lb cans") to coat my ATV frame. I coated all the small items first to get used to the powder. I had a few problems with color/coverage so I stripped and re-did the parts using the "other cans" well everything came out fine. So I decided to do the frame. It wouldnt fit in the oven so I take it to have it done. It came out bad.. The powder which is supposed to be a nice bright candy orange looks more like a copper color and has fisheyes in it. The shop that shot and cooked the frame said that the chrome came out awesome. But after applying the orange and re-baking it turned out ugly. Is it possible that my powder was bad since this happened to myself and another PC shop?
gold , orange, yellow , brass and some coopers almost never reach the desired colors unless used over real chrome or polish surfaces
if they are used over chrome powder they loose it's colors deeps for the spots in the pictures that is a coating problem noting to do with the color it could have been a Ground problem. Last edited by jtagger19; 04-26-2006 at 07:05 PM. |
funny you talked about that ,today at the shop i red the lebel on my can of chrome
one said cure at 400 for 14 minutes and the second one cure at 400 for 10 minute (same item number) after i cure th e parts and let it cool,the chrrome was nice but scrach very easy and i did it the right way, something wrong ![]()
It does take away some of the reflectivity, there's no getting around that. There is "another" manufacturer that sells Single Stage Reflective Chrome, doesn't need a clear coat, so it stays reflective.
No, I don't normally use a primer unless the part is continuously out in the weather. Most of what I do is Custom cars, hot rods, bikes, sleds. Most of them are stored indoors. mach
TSA Custom Metal Finishes Live fast, Die sideways |
If you are coating something like a picture frame, or something that is indoors, do you still need to clear coat over the chrome? I thought I also read somewhere that the chrome will rust if it is not clear coated?
SS |
