Hello all,
In my latest project, I used a candy lime powder which turned out fantastic at first glance. The problem is, the closer I got to the part, I noticed little black specs in the finish. I figure it was from not cleaning the gun out well enough, but I blow out the gun really well in between powders. Could these specs be from powder floating around in the air or in the oven? Is there any other way of cleaning a gun besides blowing it out? Anything will help. Thanks guys. |
I use a couple different gun cleaning brushes on mine. I broke the glue joint loose on the barrel so I can remove and clean better.
Make sure you blow your oven out once in a while as well. |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 08:37 PM |
| Tips and Tricks | non-stick | Powder Coating Questions | 27 | 11-11-2007 03:01 PM |
| Powder crawls away | PatrickMcGovern | Powder Coating Questions | 4 | 04-29-2006 03:04 PM |
| Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! | Mcurtis7 | Used Items For Sale | 0 | 10-02-2005 03:18 PM |
| Gun spitting excess powder | pdeinc | Powder Coating Questions | 8 | 10-21-2004 04:21 PM |
