Hi mach,
Yes, I coated one and there was no rubber in mine... But here is a link: Marine application Good luck frank |
We did a valve cover for a customer who cleaned it himself. 4 rubber seals buried in holes. When it came out of the oven, they had dried and shriveled. Rubber and plastic parts must be removed. They were at the point if they had been in the oven any longer, they probably would start to burn!
M & J Sho Me Coatings |
Got that, but this is unremovable. I was wondering if this type of rubber/application would hold up to the low end of a cure cycle.
Thanks! mach
TSA Custom Metal Finishes Live fast, Die sideways |
Mach, I PC'ed a rear wheel off a Honda Goldwing that has five non removable rubber bushings inside. The wheel went through outgas basecoat clearcoat with no problems. The area was recessed so I cut a piece of high temp insualtion and taped it into the recess to help seal the direct heat from the bushing. Dont know if this will help on your prop but this wheel done fine with no signs of dammage on the bushings.
Jason |
| need tower (boat) powdercoated or re-anodized | rdoming | Services Offered/Wanted | 1 | 03-07-2006 02:35 PM |
| i got flooded !!!!! my oven turned in to a boat | customandsound | Powder Coating Questions | 16 | 10-03-2004 08:09 AM |
