Was looking in grainger book at dissicant air dryers and was wondering if anyone is useing one.Are they used by themseles or in conjunction with something else?Seems that some can be dried out and reused and some have to have the drying material replaced at what appears in some cases to cost more than the unit.Which type works the best?Do they work at all?If these things work it looks like a good solution for around a hundred bucks.
quite often the dessicant can be oven dried so that you can re-use it. If the unit's cartridge wont allow for baking, then modify it so that you can remove the dessicant for baking, then replace into the cartridge.
59 Volvo PV544 87 Shelby CSX #239 88 Shelby CSXT #707 88 Shelby CSXT #745 87 Mustang LX 92 Mustang GT www.jamperformance.com |
I currently use an air dryer, but have used dessicant in the past and it works really well. You have to keep in mind that you will need to keep it maintained and you shouldn't have any problems. I would reccomend also putting a water seperator inline before the dryer though. Water seperators with a paper filter are cheap buy and replacement filters are cheap as well, and can make the dessicant last quite a bit longer.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
I was thinking out loud there. I couldn't do stainless, unfortunetely, not set up for it. Welding would be involved there. I still may make a small drier with PVC for the PC gun.
If I could find a ready made cylinder that I could adapt to a dess filter, that would be a big help! Mike Sho Me Coatings |
| will regular paint gun work with tech line coating | corybarta | Other Metal Finishing Questions | 34 | 08-25-2006 02:58 PM |
| would a gas grill work for powdercoating in a pinch? | turbotim23 | Oven Building Forum | 1 | 03-09-2006 07:08 PM |
| Do you think this dyeing method will work? | Paintbalaguy | Anodizing Questions | 3 | 09-17-2005 02:04 PM |
| Tech Line Coating, will this gun work? | Noob2PC | Powder Coating Questions | 11 | 10-17-2004 06:37 PM |
| work area vs. cathode area | elton10 | Anodizing Questions | 4 | 03-25-2004 10:59 PM |
