Old 05-28-2006, 10:58 AM
krymis is on a distinguished road
Default anodized aluminum tip...
guys i got a tip that i use for doing aluminum parts that are anodized. A lot of searches turned up q's on how to get anodized layers off. I use my anodizing chemicals. I use a lye solution of 16oz. lye (red devil or draino found at walmart or lowes) poured into a five galllon bucket with three gallons of distilled water. Let part soak for 5-30 min. Rinse. Then its over to the deox desmut tank. After the deox/desmut tank I rinse and repolish it. I do a few sport bike brackets, so i use a plastic storage bin of 20 qt. from the house section at walmart. I mix up a 2 gal desmut mix. dip the part for 5 min at room temp. Then get an anodizing cleaner. PM if you would like to know where to get my chemicals. I heat the solution to 140 you could do this in a microwave. Dip the part let sit for 5 min. Pull out, let air dry, and powder. No contaminates so far and the finishes are turning out great with the clears and solids. I still can't get the knack of the candies. I have done one pulley 4 times with horrible results. I hope this helps and contributes something to the board. I am not saying this is how you have to do it either. This is just a way that i found that worked for me. Thanks to the guys here for their help.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
cleaning anodized aluminum rancidnsx Anodizing Questions 0 01-27-2005 12:56 AM
Procedure to strip anodized layer off aluminum. remarc1 Other Metal Finishing Questions 1 07-27-2004 05:41 PM
anodized aluminum pore dimension sam4 Anodizing Questions 2 03-11-2004 08:57 AM
Chroming anodized aluminum. hifi Electroplating Questions 4 08-05-2003 01:23 PM
