2. What? If you are referring to outgassing it is machined cold rolled steel that shouldn't need outgassing. It doesn't show any signs of outgas anyway, just a rough finish that is comparable to "dryspray" in the automotive painting world. 3. Yes Anyone else have any thoughts? |
I did the stands a while ago. I coated them (one at a time) and put them in the oven @ 500 degrees. I kept an eye on them until they got up to 370 degrees and then turned the oven down to 375 and opened the door for a few seconds to help get rid of some of the heat. The parts cured @ 375 for 20 min.. They looked great this time. I think what happened before is that I set the oven to 375 from the beginning and it took like 40 min. to just get up to 310. Then I turned the oven up to 500 and didn't keep a close check on it. The metal temp was well over 400 by the time I caught it and I didn't leave the door open to let the 500 degree air out. I believe that it just didn't stay in its "flow" period long enough to get slick. Thanks for the help.
| PLATING POT METAL............... | 48Buick | Plating Pot Metal | 31 | 08-29-2007 12:40 PM |
| Plating over cold metal casting | jh2ohouse | Electroplating Questions | 2 | 12-16-2006 09:28 PM |
| Plating pot metal for corrosion protection before painting | rspencer | Plating Pot Metal | 2 | 08-03-2004 12:39 AM |
| Consistency Problems | NeoMoses | Anodizing Questions | 6 | 12-13-2003 04:01 PM |
| Refinishing Metal Golf Club Heads | BillSchultz | Other Metal Finishing Questions | 0 | 08-17-2003 11:40 AM |
