By any chance did you simply wipe the wax/grease remove over the part with a cloth, instead of spraying it on?
I have tried paint thinner for part cleaning, and the results were awful. It was as if the paint thinner left oil behind that showed up during the cure. If you cleaned the part with thinner, then wiped it down with wax/grease remover, it wouldn't clean the paint thinner residue out of the pores and you'd probably see something like what your picture shows. I stopped using paint thinner because I could never be sure I had gotten it completely flushed out of the pores of the metal. Not sure if that's the problem, just a wild guess Steve |
cruizer,
First why are you using a Gease/wax remover? You did say you are outgasing correct? if so just use Acetone as a wipe on or from a spray bottle. The less you put on after it has been Outgassed the better. Steps: Sandblast, Spray with cleaner, outgas, cool then powder.. Jim S...
Jim Shuster www.backyardpowdercoating.com Sold..... www.chrissys68mustang.com Hobbie www.photogserver.net Web Hosting. |
I have found that everyone uses so many different chemicals, it's hard to compare notes when something goes wrong.
Brake fluid, acetone, alchohol and a long list of others are some that are being used by PC'ers here on the forum. Doesn't anyone just use the phosphate cleaners ![]() Mike Sho Me Coatings
Mike & Johnny Sho Me Coatings |
I did the same thing over an intake pipe a while back. I sandblasted, prepped with iron phosphate, outgassed at 8 minutes, shot the chrome, baked at 400* for 10 minutes, shot the liquid smoke at around 180*, cured at 400* for 20 minutes. Came out flawless.
I have had the same problems with chrome over thin metal like the intake pipe, valve covers and a bike fender. I have seen it with both super chrome and xtreme chrome. On thinner substrates I have started putting on two coats of chrome and have had no more problems. I put the second coat on right after the full cure of the first coat. Just be careful and dont lay the second coat on too thick.
Jason www.autocyclepc.com |
Johnny
| Cartridge rolls - description wrong? | mpierich | Caswell Please Sell This... | 1 | 06-15-2005 12:52 AM |
| Ok,what am I doing wrong | mach1man | Metal Polishing Questions | 1 | 08-18-2004 08:31 PM |
| cant figure out the chrome | Carcher7878 | Powder Coating Questions | 2 | 05-21-2004 02:05 PM |
| What's wrong here...... | dsacco1013 | Powder Coating Questions | 2 | 01-05-2004 11:15 PM |
| What am I doing wrong here | PC101 | Powder Coating Questions | 3 | 06-29-2003 11:14 PM |
