Here's my opinion, and it's just only that. We have a elec. oven which we made bigger, thats what we mainly use.
I also got a m1500 lamp and it works ok. Just seems to take a little longer. I tried my hot head propane heater and it kinda worked the same. Key is to mointer the temp. with an IR gun. I got the same one they sell here and its well worth the coin at getting a good finished product. |
I use a kitchen oven. I will be upgrading to an industrial oven soon, but will also be picking up an IR lamp for larger flat objects. I've seen the lamps work and in my humble opinion they do work well. If you have patience and take care in checking the temp and moving the lamp as needed you will have a positive outcome.
Armani I wouldn't advise using a torch. You could end up getting a Darwin award. I have seen people use a toaster oven with great success when coating small parts. The bottom line is that you can use a kitchen oven or an IR lamp with great success. Use what ever method fits your situation. If you only have a 110v 20a circuit you'll be using an IR lamp. If you have 220 100a use what ever you can afford. If you have little room to work with you will be better off with the IR lamp, as it is portable. You can also add to it using another lamp after you get a good work flow going. Just remember that you do need to be patient and diligent when it come to material temp. Good luck. tomg552001, Where in NJ are you from? |
I am as well. I never even looked at the date on the post. I was wondering why you said you were getting closer to purchasing equipment. I've been out on your site, and I have to say...NICE WORK! Where in northern NJ ? I'm in Parsippany
Yea...it's small but building pretty quickly. How is your shop doing these days? What kind of work do you do most? Sounds like an interrogation. It's really not, I do like to get to know other coaters in the area. We talk and share info and resources, and even powder in an emergency.
Where in parsippany is your shop? Do you have a home based shop or commercial? I run a home based...much easiar and there is nothing really commercial availible around here. I've been doing really well lately...i'm just finishing up building a larger shop as we speak. I do mostly car parts for imports etc, but ive done a few other odds and ends...with the new shop i plan on expanding into a few other areas and coatings aswell. If youd like, send me an email and we can get in touch.
| powder coating over powder coat? | corybarta | Powder Coating Questions | 6 | 08-21-2006 09:15 AM |
| Finding a place to powder coat | RCLSolutions | Powder Coating Questions | 3 | 05-04-2005 10:42 PM |
| powder coat curing in kitchen oven? | iceboy | Powder Coating Questions | 7 | 01-29-2005 01:57 AM |
| Laser printer = Powder Coat Printer? | tbloss001 | Powder Coating Questions | 11 | 08-30-2004 07:08 PM |
| curing powder coat | ricelake | Powder Coating Questions | 1 | 02-28-2003 11:00 PM |
