I searched, but did not find info I'm looking for ( probably a poor search :^) ). In any case, I have two motorcyle wheels ( aluminum ) with the original pwdr coating left in all the difficult spots. I've tried: - 'aircraft stripper', so named on the spray can - wire brush on drill, works ok except on hard to reach areas - sm. wire brush on dremel tool, reaches hard areas but wears down almost immediately :^P - heat gun, almost no effect - MAPP gas torch, also almost no effect in reasonable time I noticed on the Caswell site that a soln. of battery acid can remove plating from aluminum, so my question is, can it also efficiently remove powder coating? I apologize in advance if this question has been answered, & ask to be pointed to the answer. TIA, Anders |
I use a product made by Mar-Hyde called tal strip. It is in the class of aircraft stripper and works very well on powder. I got it at my local automotive paint supplier. The key to this stuff is patience. I stripped some auminum wheels after useing chrome powder and clear on them and it took about half an hour to lift the powders from the wheel. Hope this helps!
Yup, I use TAL Strip too with good results' let sit for about 20 min and scrape off. do not let it dry on the part though.
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
I'm doing the same thing to a couple of motorcycle wheels right now. I found the easiest way to paint the stripper on is to use a wide, shallow galvanized bucket that I found at Home Depot for about $14. I set the wheel in, pour about a quart of stripper in, and start slopping it all over the wheel, over and over, for a half hour or so. Sometimes it takes that long for the stuff to come off. The bucket is sure nice compared to setting the wheel on a piece of cardboard or whatever and brushing the stuff out of a cup. The key seems to be keeping it wet with fresh stripper for a good long time.
Steve |
I just tried a product called Carbon-Off.. its used for removing carbon from cooking pans.. i tried it on a hunch .. and it wirks quick.. smells like ****.. but works.
If it jams; Force it. And if it breaks it needed replacing anyway. I can go from 0 to "What seems to be the problem Officer?" in 3 seconds." |
NAPA brand carb cleaner. I initally got 20 gallons of it and filled up a parts washer container. Then soat parts in that. its not cheap at $80/5gallons unless you have a buddy who gets it for you. Then its about $60. but It works awesome. Thats all I use.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
| Two Tone Powder Coat | engineerscott | Powder Coating Questions | 5 | 03-27-2006 12:44 PM |
| Finding a place to powder coat | RCLSolutions | Powder Coating Questions | 3 | 05-04-2005 10:42 PM |
| Laser printer = Powder Coat Printer? | tbloss001 | Powder Coating Questions | 11 | 08-30-2004 07:08 PM |
| Powder Coat Removal | 04sp500 | Powder Coating Questions | 4 | 09-19-2003 06:46 PM |
| Powder coat question. | Josh I | Powder Coating Questions | 1 | 03-28-2003 10:35 PM |
