Old 06-20-2006, 02:25 PM
Livinincolor's Avatar
Livinincolor is on a distinguished road
Send a message via Yahoo to Livinincolor
Default Let's talk about Lab Metal
I need to hear from those of you that have used Lab Metal.
What did you use, hi temp or the other?
How bad is it to work with?
Was sanding it that bad?
Did it take pc well or...?
I have a couple projects that would look a lot better if some of the deficiencies were filled in! It would really make a big difference in the overall look, but I haven't heaqrd anything good about the product other than it's a real bear to sand!
Johnny
Mike & Johnny
Sho Me Coatings
Old 06-20-2006, 02:34 PM
Default Re: Let's talk about Lab Metal
I ahvn't used Lab yet, but I have some Devcon 2 part epoxy putty here I have used. It accepts heat well, good to 750F and takes the PC good too. Pretty hard to sand. Harder than Fiberglass. But it flows pretty smooth in it's cure process, which takes overnight at room temp, but faster in the oven. Can also Machine/mill/tap the stuff. I have used it for repairing stripped/broken boltholes
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 06-21-2006, 09:34 PM
robsrod is on a distinguished road
I have used it works great, sets extremely fast!
Old 07-17-2006, 04:49 PM
mtnbiker is an unknown quantity at this point
I have used the high temp stuff. Real easy to use. Just be sure to mix it real well before you try to use it.
Sands easy... couldnt tell it was on there at all.
Old 07-17-2006, 07:03 PM
JeffL
I would like to know how well it takes to powder too? I'm finnally getting near the point that I'm gonna be doing my first part.I have some parts that are pitted from rust, & was wondering wether Lab metal or JB Weld would be better to use.
Old 09-24-2006, 06:32 PM
chcustom is on a distinguished road
I used JB Weld on a gas tank and it was really easy to work with when applying and sanding. It seemed to take the powder well too.
Old 10-03-2006, 09:30 AM
I used the high temp LabMetal. Worked great. Easy to sand. Couldnt tell it was under the powder at all. just make sure you do the prep work right.
Since you asked....Lab Metal vs. PitStop ?? dwoodruff Electroplating Questions 6 09-18-2007 07:48 PM
PLATING POT METAL............... 48Buick Plating Pot Metal 31 08-29-2007 12:40 PM
Lab Metal speedyshark Powder Coating Questions 3 04-29-2006 05:53 PM
Refinishing Metal Golf Club Heads BillSchultz Other Metal Finishing Questions 0 08-17-2003 11:40 AM
