Old 06-21-2006, 01:44 PM
KZjim's Avatar
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
Default "Orange" brand gun...
Have an "orange" brand gun?.. with crappy, inconstant flow?.... try this.. remove the cup.. if the air inlet hole is pointed into the gasket.. rotate it around 180*... it works like a champ if you do....
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
Old 06-21-2006, 02:35 PM
cruizer's Avatar
cruizer
Default Re: "Orange" brand gun...
Really? Spanks!
Old 06-22-2006, 03:11 AM
azoldbill's Avatar
azoldbill is on a distinguished road
I've also followed the advise of someone else on this forum by drilling 1/8" holes 90 degrees to the original hole. Much better fluidization. Goes through powder a little bit quicker, but definately a better mist of powder.
Old 06-25-2006, 03:42 PM
KZjim's Avatar
i though about adding an extra hole.. but decided to try it just rotated first.. i actually had to drop the regulator psi to about 6lbs 'cause the flow was strong.. but i moved it back to 10psi and used the regulator in the handle.. just in case i needed the boost i could just twist it up...
Old 07-22-2006, 02:05 AM
TemperanceCoaters is on a distinguished road
Im confused on what you are saying. Pointing into the gasket?
Old 07-25-2006, 01:42 PM
upncoming's Avatar
upncoming
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
same here is there any pics of your setup you could show us on your setups?
D.I.L.U.S.I.
Drive It Like You Stole It
Old 07-26-2006, 03:35 PM
KZjim's Avatar
i'll take some pics and post them later today...
