The closer I get to purchasing your kit, the more I realize that an oven won't suit all my needs. Most, but not all of the stuff I will be doing will easliy fit into an oven. However, there will be large pieces (Vespa frames) that will not.
How effective are these heating lamps? Do you have to enclose them to aviod heat loss? What kind of curing coverage to you get (or, how large an area will the heat lamp cure at one time.)? Thanks |
The lamp is simply providing heat to the metal. If its a flat wide sheet, it
will heat up quickly, if its a bike frame, a lot of the heat will pass by. This can be returned by using a reflector. Lamps will easily do bike frames and even car chassis. You simply cure 1 section at a time. The lamp will do the area a bit bigger than its length & width. They work like a charm!!!
How sensitive is the powder when curing? After the powder is applied I assume you cannot touch it at all. If I'm doing a frame I will need to move it around quite a bit to cure all sides. I'm wondering if it's best to suspend the frame and just move the curing lamp around - but I'm still wanting to know how sensitive the powder is before drying.
thanks |
Yes, suspending it and moving the lamp around would be best. The powder is very sensitive...you don't want to touch it. It's also easily blown off, so avoid moving air.
| Curing Lamps | asallwey | Powder Coating Questions | 3 | 09-30-2004 08:36 PM |
| Curing Lamps? | trsick | Powder Coating Questions | 3 | 08-06-2004 01:57 PM |
| Curing lamps | johnny933 | Powder Coating Questions | 0 | 04-20-2004 06:40 PM |
| about the curing lamps... | trest | Powder Coating Questions | 5 | 06-15-2003 03:28 AM |
