FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 08-16-2006, 04:27 AM
oldgoat69 is on a distinguished road
Default Pre Heating
I have been powder coating most of the removable parts on my Harley and they are coming out looking pretty good. The problem I am having is with the wheels. I have polished the edges of the wheels and have been using Caswell's tape to cover the polished areas. After taping the wheel, I pre heat the wheel to 450 to out gas it, let it cool to about 200 and then shoot it with super wet look black.
The tape has been baking itself to the wheel and I end up scratching the finish trying to remove the tape and end up having to redo the whole process. Can I preheat the wheel to 450 to out gas it, let it cool to room temp, tape it, give it another wipe down, and then shoot the black, or by doing this am I defeating the purpose of pre heating and out gassing?
Old 08-16-2006, 09:30 AM
Default Re: Pre Heating
Pre heat let it cool and tape it. I assume these are the standard Harley cast aluminum wheels? I have done a few sets of these and had to redo every one. Not because of problems with the coating...These wheels actually come out great. It was because every one wanted to do what you are describing and when they were finished they all hated the way it looked. For some reason when you get em on the bike they look terrible with the spokes and beads polished. I did redo one with the spokes and beads done in burnt orange, and it came out looking pretty good.
Old 08-16-2006, 01:09 PM
Thanks for the reply. The wheels are the stock 9 spoke Harley wheels. The parts of the wheel that I am polishing were powder coated silver from the factory. The rest of the wheel was a flat black and is getting the Super Wet Black. I somehow managed to get the front wheel done and it looks good.
The rear wheel is causing the problems. I guess that because of it's extra mass, I have to leave it in the oven longer to get it up to temp and the extra time needed is baking the tape. I will try pre heating first and then taping it this time.
Old 08-17-2006, 12:58 AM
cdaeme's Avatar
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
The way I do polished wheel lips is mask with vinyl reminants from a local sign shop. The vinyl conforms much better than the green tape in this situation. I would then put the wheels in the oven until the powder flows out. Then pull them back out and peel all the vinyl off put them back in the oven and finish the cure. With wet black I have found it is much easier to let the wheels cool first before trying to remove the vinyl because the wet black will string out when it is still hot.
Jason
www.autocyclepc.com
Old 08-20-2006, 11:56 AM
mtnbiker is an unknown quantity at this point
Most of the high temp tapes are only good to 400 degrees.
Personally, I never outgas with tape, always tape after the outgasing step.
Old 08-20-2006, 11:57 AM
The vinyl stands up to the heat ok?
Old 08-25-2006, 10:07 PM
tnc tnc is offline
tnc is on a distinguished road
450 is to hot for the green and blue tapes. You must use the 500 degree tape when heating that hot. Also if you try to remove the tape while it is still warm (not hot or cold) it is a little easier.
  #8 (permalink)
Old 08-26-2006, 12:32 AM
cdaeme's Avatar
I only leave the vinyl on until flow out. I recently coated a pair of Yahama wheels and I masked 4 times before I finally used the vinyl and all the other tapes lifted terribly and the vinyl was easy to form into the curves of the wheels with no lifting as all.
Jason
Alternate solution heating idea? dagobert Electroplating Questions 6 09-02-2004 11:26 AM
out gasssing and pre heating? randygrapes218 Powder Coating Questions 2 06-26-2004 04:54 PM
Custom oven material and heating element help needed DarinReiss Oven Building Forum 13 12-27-2003 09:24 PM
Tank Heating Questions. meganine Anodizing Questions 1 08-03-2003 03:20 PM
Heating electro-less nickel ? stevec Electroplating Questions 1 04-30-2002 05:00 PM
