Old 10-05-2006, 09:10 PM
lfsracing
Send a message via AIM to lfsracing
Default High Temp Ceramic powder
Just wondering does anyone know where to get some good high temp ceramic powder? Looking to coat some exhaust pieces and turbo pieces that can get really close to 1600 degrees. The current turbo setup on one of my cars puts out close to 1600 EGT's which is quite hot. I know they make stuff to do temps this hot and just don't want to risk coating something with the high temp powders that I seen on caswells site without knowing they will be able to handle it. Any help would be great. Hopefully this is something caswell would consider getting in as I need to order some things already so would just add this to my list.
Lorenzo
Old 10-05-2006, 09:34 PM
RNMHRD's Avatar
RNMHRD is on a distinguished road
Exclamation Re: High Temp Ceramic powder
Check Caswells site.. they sell "tech line coatings" black satin.
its a ceramic spray on coating thats for exhaust and is rated to 2000-deg.
Old 10-05-2006, 09:52 PM
hvac36's Avatar
Moderator
hvac36 will become famous soon enough
Send a message via AIM to hvac36
Default Re: High Temp Ceramic powder
Lorenzo
Lorenzo,
There is no such thing as High Temp Ceramic Powder, the ceramic coat is a wet product. As RNMHRD said look for Tech line coatings, I use then all the time. You will need an oven that reaches a min temp of 500 degrees..
Jim S...
Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
Old 10-05-2006, 10:09 PM
lfsracing
Never even seen those.... Just clicked on the link. Looking for more of a silver color though. If anyone has used any of these how did you apply them? I know the last one says to bake it at 500 for at least 1 hour. Anyways what did you use to coat the header spray it? etc? Any help would be great. I have a cheapo header I am going to probably use for testing purposes but I just want to make sure I do it right the stuff is kinda expensive to waste... Any help would be great as well. Also does anyone know if the High Temperature Powder For Headers & Exhaust Applications powders are like? Anyone use them? I have non turbo apps that I can probably use them on being they don't get so hot. But this was what kinda color I was wanting to use.
Here is a picture of my turbo that I had done when I bought it. I need to find something similar to this.
Black Satin (BHK)
Black Satin is the most advanced exhaust system coating available
Withstands 2000f temperatures
Easy to apply ceramic reinforced coating designed for high temperature applications
Reduces underhood temperatures, reduces exhaust manifold surface temperatures
Improve exhaust gas velocity, increase H.P.
Air drying, requires no baking
Coverage: See above
ColorGard
Extreme temperature exhaust system coating.
Available in several colors (see below)
Coverage: See above
Bake On Ceramic Coatings
CermaBlue
Metallic Ceramic Coating
Excellent corrosion protection
Tested to over 1300f base metal temperatures/1600f Exhaust gas temperatures
Polishable and provides a variety of colored finishes depending on the polishing time.
Water based with no flammable solvents.
Can be applied to any metal that can handle the cure temperature, except magnesium
Available in quarts
Requires baking. Cure temperature 500f for 1hour minimum.
Old 10-05-2006, 11:20 PM
as far as my experience
high temp powder don't work on any kind of header they peel off after a couple uses
ceramic coatings is the way to go for headers
Old 10-05-2006, 11:23 PM
lfsracing
How does that stuff get applied? Any info would be great.
Lorenzo
Old 10-06-2006, 09:55 AM
lcaswell's Avatar
Caswell Inc President
You're probably looking for our Chromex product, which is a ceramic coating that looks like chrome.
It's listed here: http://www.caswellplating.com/powder/ceramics.html
It's applied with an HVLP gun and is baked. Instructions are on the web page.
Lance Caswell
Have A Web Site?
  #8 (permalink)
Old 10-06-2006, 11:10 AM
lfsracing
I wish it could hold up to 1600 degree temps though like the other stuff. How is the other stuff that I was told about get applied? Not the chromex stuff.
Lorenzo
High temp coatings KeithLambert7 Powder Coating Questions 2 04-30-2005 04:25 PM
High Temp Powder?? trsick Powder Coating Questions 13 10-11-2004 08:25 PM
any experience w/ high temp on headers RossL Powder Coating Questions 2 05-05-2004 08:11 PM
Can I use VHT high Temp with Krylon High temp radiator paint magnus Other Metal Finishing Questions 1 05-03-2003 11:20 AM
