I just bought the 30-50 kv gun. Im having alot of problems getting powder to come out. I have to smack the cup to get anything. I have adjusted the air flow, filled the cup up a little bit, then half way...still not working right..
Anyone else experience this? what, if anything fixed it? Thanks for any help. |
Powderman, The silver screw on the handle. Get a wrench and completely take this out of the gun. You may have to unscrew the the adjustment screw as you loosen the hex nut. When you get it all apart, you will see a white plunger on the end of a small shaft that screws into the adjustment screw. Mine was loose and I had the same problem. Tighten that connection between the two parts up then reassemble. I would screw the adjustment screw into the hex nut before I put the hex nut in the handle. As you start to tighten the hex nut, pay attention to the adjustment screw and back the adjustment screw out if it starts to bind at all. If you do this until you get the hex nut tight. You should be golden. Greg
Had to fix mine as well! when I got it the switch in the back just spun freely. Found it was missing the nut that held it in. When I did get it fired up had the same mixing screw problem. Maybe a little to fast to the shelf....
same for me
i had to fix mine now the flow is ok, but for the rest that gun work well , better than the E ...gun,on larger pieces,next week i will pc an atv frame somebody did it whit the new gun? if so feedback will be appreciate |
| Better fluidizing in the hobby gun? | cruizer | Powder Coating Questions | 15 | 09-21-2006 07:13 PM |
| want educated on caswells new gun | skooterbum | Powder Coating Questions | 7 | 09-14-2006 09:52 PM |
| Professional gun? | mtnbiker | Powder Coating Questions | 10 | 03-14-2006 10:25 PM |
| Hey another question! Powder Gun acting weird | cruizer | Powder Coating Questions | 3 | 10-06-2005 06:11 PM |
| Consistency Problems | NeoMoses | Anodizing Questions | 6 | 12-13-2003 04:01 PM |
