i am not a pro at this but i would use the phosphate if it was me. helps guarantee better adhesion. as far as a damp cloth i would only have the phosphate on the cloth, i thought you might be refering to wetting the cloth with water to dampen it then applying the phosphate. ron |
Thx Ron., I was referinng to just dampening the cloth with Zinc Ph Solution, So, the Zinc and water mix that the directions say for dpping. Or would full streingth be better?
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
Thanks alot I hope I think maybe I will continue to remove the old pc, by chemical (airplane stripper) works real good so far. is there anything I should do after other than rinse it off with water? and do I use the zinc phosphate just before I tape and plug?
| metal prep question | corybarta | Powder Coating Questions | 2 | 03-09-2005 02:49 PM |
| Prep metal for chroming | ggcr | Electroplating Questions | 3 | 11-26-2004 02:27 AM |
| Using OSPHO for metal prep? | Blademan | Powder Coating Questions | 0 | 03-31-2004 10:06 AM |
| how to prep metal for painting | coorsman | Other Metal Finishing Questions | 2 | 08-16-2003 06:26 PM |
