+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 23
Thread: metal prep NEED HELP PLEASE
  1. #1
    Default metal prep NEED HELP PLEASE
    i am having problems with pretreatment of metal. i have used picklex and ortho from ace hrdwr. both leave gooie trails and balls on parts. my last attempt was with the ortho. i sprayed it on and let it set for 15 min then rinsed it off, no goo but had flash rust on parts. i am missing something here and would really appreciate any and all ideas on this. my work is starting to accumulate and i am learry to continue on till i figure this out. also i have found that black beauty is to aggresive, it leaves to rough a finish even after going over part with scotch brite. i would like to simplify the operation some what. what recomendations does anyone have for this one also.
    thank you all in advance
    ron
    Share with Facebook
  2. #2
    Default Re: metal prep NEED HELP PLEASE
    i think i the ortho should be ospho sorry its been a long trying day!
    ron
    Share with Facebook
  3. #3
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,283
    You may need to checkout the phosphate primer Caswell offers. It's made for powder coating.
    http://www.caswellplating.com/powder/pcprimer.html
    I use ospho all the time doing restoration work and what you describe is just the nature of the beast. I use glass bead, brake wash and compressed air to prep most of the parts I do.
    SS
    Share with Facebook
  4. #4
    Join Date
    Jan 2004
    Posts
    277
    I never had any success spraying picklex. I just wet a rag with it and wipe it on. I use lint free rags and it works great for me.
    Share with Facebook
  5. #5
    bzer1 do you have any problems with the picklex acting as an insulater and not getting good powder coverage i used the ospho on last attempt and seemed like the powder was not covering as good as on bare metal. i have a hobby gun and am wondering if i need to step up to a better gun now.
    thanks for all the help here
    ron
    Share with Facebook
  6. #6
    Join Date
    Jan 2004
    Posts
    277
    It sounds to me like you probably need to find a better ground. These conversion coatings shouldn't affect transfer. I have never had an issue with that myself. In your case I might be tempted to test it with a multimeter just to make sure that you're getting a good ground. Using a conversion coating shouldn't be a show stopper, even with a hobby gun.
    Share with Facebook
  7. #7
    thanks for the help i will check the ground for sure. never gave that a thought. one more question on the picklex do you or can you put part in oven after picklex to speed up the drying time or is it best to let air dry
    i really appreciate all the help on here!!!!!!!!!!
    thanks
    ron
    Share with Facebook
  8. #8
    Join Date
    Jan 2004
    Posts
    277
    I wouldn't if I were you. It will stink the place up, and you really don't want the vapors sticking to the inside of your oven. Definately do not try to hit any parts with picklex until they're cooled down. Just let em air dry. When I'm waiting for it to dry I use that time to fill the gun and do other prep like put plugs in the part. So basically here's how I do it.
    Accept and tag the part
    Check the part for obvoius damage and note.
    Degrease and clean the part
    Sandblast or strip the part
    Check the part for not so obvious damage
    Call customer with the bad news
    Make necessary repairs
    Outgas
    Apply conversion coating(picklex, Chromate, Phosphate...)
    Plug, mask, and prep gun and booth while drying
    Shoot it
    Bake it
    Remove from the oven and hopefully admire my work.
    Share with Facebook
  9. #9
    bzer1 thank you for all your help it is greatly appreciated!!!!!!!!!
    thanks
    ron
    Share with Facebook
  10. #10
    Join Date
    Jul 2005
    Posts
    206
    When you guys use Ospho, do you spray it on and let it dry? If so, how do you prevent the thick crud that accumulates at the bottom of the part?
    Or do you let the Ospho sit for a while, then rinse?
    I tried the second method once and seemed to get a thin layer of rust when it dried.
    Steve
    Share with Facebook
+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Thread Information
Users Browsing this Thread
  1. metal prep question
    By corybarta in forum Powder Coating Questions
    Last Post: 03-09-2005, 01:49 PM
  2. Prep metal for chroming
    By ggcr in forum Electroplating Questions
    Last Post: 11-26-2004, 01:27 AM
  3. Using OSPHO for metal prep?
    By Blademan in forum Powder Coating Questions
    Last Post: 03-31-2004, 09:06 AM
  4. how to prep metal for painting
    By coorsman in forum Other Metal Finishing Questions
    Last Post: 08-16-2003, 05:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
