FREE POWDER COATING SYSTEM
There are several things that could have gone wrong.
1. Over cure on one piece(most likely) 2. Not enough powder(potentially) 3. Blooming on one piece(least likely) If I were to hazard a guess I'd have to say that it's most likely over cure. You might have a hot spot in your oven or the clear might be curing too fast. I've had problems in the past with milky clear coats. It turned out that most clears are low cure formulas. You might want to lower your cure temp a bit and your dwell as well. you might also let your oven temp drop below your cure temp...say 100* and put your parts in at something like 225* and cure at 325*, the check them at about the 10 min mark. I currently have 10 lbs of clear that has a cure temp of 275* for 10 mins. It will have significant over cure problems if I try to cure at 300*. |
i will try the 275 for 10
D.I.L.U.S.I. Drive It Like You Stole It |
| polished. now powdercoat clear? | hybred | Metal Polishing Questions | 5 | 04-01-2006 10:37 AM |
| Super mirror black or low gloss black? | Deecoat | Powder Coating Questions | 2 | 03-09-2006 10:24 PM |
| Real Black and Shiny Clear Chromates | XK120DHC | Caswell Please Sell This... | 1 | 08-30-2005 04:23 PM |
| Caswell burner black? | mtnbiker | Powder Coating Questions | 1 | 04-13-2005 12:15 PM |
| Why does my clear on top of glossy black look crappy? | Heavykote | Powder Coating Questions | 7 | 03-21-2005 01:29 PM |
