Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 10-26-2006, 10:49 PM
boston_jake01 is on a distinguished road
Question Powder coating motorcycle eng.
I just removed and cleaned the engine and trans. I wanted to powder coat it glossy red.
1. do I need to remove all the old powder coat?
2. can I get a smooth look even if the eng and trans aluminum is not smooth?
If I need to smooth the eng. and trans. what would be the quickest / easiest way?
Thanks
Old 10-26-2006, 11:32 PM
Default Re: Powder coating motorcycle eng.
ALL the old coatings need to be taken off, Media blasting is the best for acheving a uniform, smooth finish with great adhesion. You need to COMPLETELY tear the engine apart too. No seals, bearing's, nothin that cant handle 400*
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 10-27-2006, 10:01 AM
Thank you, what type of media do you recommend for the eng and trans and wheels?
Old 10-27-2006, 11:50 AM
would a aluminum oxide media for blasting off the old pc and smooth the eng. tran case?
Old 10-27-2006, 02:13 PM
pickleboy's Avatar
yes that should work if it is a medium to fine grit. that is what i use on aluminum all the time. again like bandit said it has to be fully disassembled and degreased. then blast and prep, powder away. by full disassembled i mean the main bearing races as well, otherwise they can losen in the cure process and then after reassembly they will spin and destroy your crank.
Old 10-27-2006, 05:16 PM
thank you very much I will be doing the trans. first.
I hope I can do it right.
Old 10-28-2006, 02:12 AM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
i agree with pickleboy, also if your transmission case is very rough you can sand it down wth 100 or 120 grit to remove all sharp edges and casting marks before blasting to get an even smoother finish
for special show bikes i sometimes polish parts to almost mirror finish before painting and then wetsand and buff the paint
but that is the high end limit,not all customers want to pay for that
Closed Thread
*** WE ARE GIVING AWAY FREE POWDER COATING *** mcaswell Powder Coating Questions 205 09-21-2009 10:55 AM
Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! Mcurtis7 Used Items For Sale 1 02-19-2009 02:39 PM
I found sand blasting aluminum prior to powder coating is a big no-no. mtumbleson Powder Coating Questions 59 04-07-2008 08:37 PM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 09:15 AM
Non-paint powder coating dshepherd Powder Coating Questions 6 01-26-2004 12:49 PM
