Questions on Cure time.
It is my understanding that cure time starts when the object you have powder coated is at the cure temperature??
If I am curing an automotive rim/wheel and it takes 25 minutes for it to come up to temperature, do I then go another 20 minutes to cure the powder coat (per the instructions on the can)?
This is a pretty good size oven, the temperature in the oven never varies from 400 degrees F. It is also a convection oven (fan inside).
I have never done this before, I have read several books. The oven is ready to go, I have the Caswell 50 KV gun. I will be using it in a paint spray booth.
Any tips would be appreciated.
Thanks
